allspeed bottom arms.
drive shafts still work, not broken yet.
The engineering company i used to make the sleeve did it as a favour to me so wouldn't normally do it i don't think.
Its Mike @ MBE race engines.
Posted 23 November 2014 - 06:56 PM
Posted 09 December 2014 - 09:53 PM
Finally got around to making (or having made for me) the inlet manifold.
So it now runs
Where abouts did you get the alloy tubing for the plenum, cant find pipe big enough apart from in the usa!
Posted 01 January 2015 - 02:30 PM
I bought a spare Engine, box and stuff for another conversion today i like this one so much.
however this one I'm going to build using :
saab 2.0 low pressure turbo Gt1752
custom manifold for the turbo, change the inlet manifold to work with the turbo
DTA ecu with boost control, making it less aggressive with lower gears so it doesn't just spin the wheels up.
Posted 01 January 2015 - 05:09 PM
so does that mean your allspeed set up will be for sale soon or is the Saab for another project
Posted 01 January 2015 - 05:20 PM
Posted 01 January 2015 - 06:35 PM
Posted 02 January 2015 - 08:49 AM
Posted 02 January 2015 - 08:54 AM
engine
gearbox
ecu
looms (to cut up unless the micra had NATS) inc relays etc.
drive shafts (to cut up so don't need the outer CV's)
gear lever assembly
both manifolds (to use only parts of them)
speedo cable.
Posted 02 January 2015 - 10:35 PM
Posted 05 January 2015 - 01:29 PM
I have a question. The subframe in the first pages is the CG13 from allspeed? and the engine are 1.3l without change the gearbox?
With this CG13 Subframe, we can fit the 1.3l micra engine without change the gearbox or we need to change for a later gearbox?
Sorry for that questions but i want to buy a allspeed subframe and i have this questions.
Thank you
Posted 05 January 2015 - 02:36 PM
AllSpeed do 2 frames, the CG10 and CG13 ones.
CG10 is for the early 1 litre engine which comes with a smaller gearbox.
CG13 is for any 1.3 litre micra engine and the 1.4 from the very last facelift micra. They both use the larger gearbox which is what the 1 litres later ended up with.
i have a 1.3 standard engine and standard gearbox for the 1.3. i changed nothing other than the clutch from that.
i hope that helps.
Posted 05 January 2015 - 02:39 PM
in other news i have been doing some further tweaks to the suspension and have settled for now with :
Toe settings :
rear = 0 (which with my adjusters was a very very small toe in)
Front = 0 or very very slightly toe out.
Camber -
Rear = negative 0.5 deg.
Front = 1.5 Deg negative.
Caster is currently 3 deg at the front, but i think i will add more and go to standard 6 deg.
This feels safe and secure on the road.
Posted 05 January 2015 - 05:52 PM
i hope that helps.
Thank you.
Only one thing. Do you have any wiring DIY? and for the NATS?
Thank you
Posted 05 January 2015 - 07:39 PM
i followed this:
http://www.theminifo...howtopic=169642
i didn't have NATS so i can't help with that.
