Allspeed Cg13De Micra Build
165 replies to this topic
#1 al_reidy
al_reidy
  • 351 posts
  • Local Club: Geeks N Freaks
Posted 01 August 2014 - 02:22 PM
Hi All,
I thought i would share my current project.
I did have a full on 1380cc A-series which was great but i just didn't like the power and cam'd nature of its performance. So i sold it.
Attached File  Micra_Mini01.jpg   47.46K   60 downloads
Then i bought a micra :
Attached File  Micra_Mini02.jpg   63.14K   47 downloads
Attached File  Micra_Mini03.jpg   60.31K   28 downloads
Attached File  Micra_Mini04.jpg   70.14K   52 downloads
Attached File  Micra_Mini05.jpg   71.79K   55 downloads
Attached File  Micra_Mini06.jpg   33.8K   29 downloads
Attached File  Micra_Mini07.jpg   75.34K   25 downloads
Attached File  Micra_Mini10.jpg   72.56K   30 downloads
Attached File  Micra_Mini11.jpg   64.35K   34 downloads
My thoughts next went to making a cable clutch pedal. Rather than weld anything i thought i would just look at what i could do with the standard pedal.
Most people pull down on the cable from the firewall above. i thought i would try using the existing pedal to pull up from under the bulkhead.
To do this i experimented with cutting off the anchor pivot thing on the end of the cable. which i then regretted !
but in this picture you see the seatbelt eyelet mount i used to hold the cable in its normal way:
Attached File  Micra_Mini12.jpg   61.04K   66 downloads
Then i drilled a small hole and with a new cable attached it to the pedal, i also added a cable guide using the orig pivot whole and 2 washers.
Attached File  Micra_Mini13.jpg   55.21K   70 downloads
Attached File  Micra_Mini14.jpg   43.15K   48 downloads
Attached File  Micra_Mini15.jpg   53.6K   31 downloads
Attached File  Micra_Mini16.jpg   45.14K   32 downloads
Attached File  Micra_Mini17.jpg   58.9K   65 downloads
Attached File  Micra_Mini18.jpg   43.73K   31 downloads
Attached File  Micra_Mini20.jpg   65.14K   44 downloads
I used a large washer either side to spread the load on the mounting.
Then the allspeed frame Arrives!
Attached File  Micra_Mini21.jpg   91.76K   207 downloads
Attached File  Micra_Mini22.jpg   66.31K   89 downloads
Attached File  Micra_Mini23.jpg   70.61K   81 downloads
which when fitted just clears the new cable mount... jammy git that i am.
Attached File  Micra_Mini24.jpg   75.27K   138 downloads
Attached File  Micra_Mini25.jpg   51.55K   68 downloads
Next was trial fitting the engine in the frame, in the car.
Attached File  Micra_Mini26.jpg   68.93K   123 downloads
Attached File  Micra_Mini27.jpg   61.64K   91 downloads
Attached File  Micra_Mini28.jpg   63K   74 downloads
Attached File  Micra_Mini29.jpg   74.19K   44 downloads
Attached File  Micra_Mini30.jpg   65.13K   54 downloads
With the clearances i then moved the engine around on the mounts, which have the ability to slide in all directions, to best fit the gear linkages and the alternator space.
Speaking of the alternator, i didn't want to just do the norm which seems to be mounting it up high over the inlet side of the engine. so i bought a small denso alternator from a Daihatsu charade which has the same pulley as the internal belt on the micra engine.
I decided i could just fit this to the front of the engine kinda in the grill.
Attached File  Micra_Mini31.jpg   53.58K   121 downloads
Attached File  Micra_Mini32.jpg   37.58K   131 downloads
Attached File  Micra_Mini33.jpg   43.71K   97 downloads
Attached File  Micra_Mini34.jpg   68.38K   112 downloads
Attached File  Micra_Mini35.jpg   33.38K   76 downloads
Attached File  Micra_Mini36.jpg   46.74K   70 downloads
Attached File  Micra_Mini37.jpg   53K   106 downloads
To make the belt fit i bought a deflection pulley from a VW engine (i don't know what) timing belt, this has an off centre hole which i use to allow ,without doing anything special, to bolt into an existing threaded mount on the side of the block.
as you can see with the alternator mount and the small size of the thing it actually works really well ! i hope when the engine actually runs it still does its job though!
Next is the drive shafts, i assembled the suspension the best i could and cut the micra and mini shafts to the best mid point in the inner pot joint travel.
Attached File  Micra_Mini38.jpg   59.23K   64 downloads
They are currently away at an engineering shop to make some sleeves, i will report back with dimensions and lengths.
Then for fun i looked at what a supercharger might look like...
Attached File  Micra_Mini39.jpg   62.61K   76 downloads
Attached File  Micra_Mini40.jpg   43.78K   39 downloads
but thats not for now...
Simple mount for the rad:
Attached File  Micra_Mini41.jpg   38.41K   89 downloads
Attached File  Micra_Mini42.jpg   40.86K   49 downloads
Attached File  Micra_Mini43.jpg   46K   58 downloads
With the Engine out i started looking at what could be done with the standard inlet manifold :
This is next to one from a Corolla, it looked like it could work but i just couldn't cut it in a way that would fit the without fouling the bulkhead.
Attached File  Micra_Mini08.jpg   46.48K   55 downloads
but i scrapped that to make my own:
Attached File  Micra_Mini44.jpg   47.25K   33 downloads
Attached File  Micra_Mini45.jpg   43.45K   70 downloads
Attached File  Micra_Mini46.jpg   29.24K   54 downloads
this is stage one, i will need to add on a plenum where i intend to add the standard throttle body on the side of the plenum.
I followed a wiring guide another user on here posted, but it turns out my micra had completely different colours. so i had to refer to the exploded diagram and make my own version. still it was a great help.
http://www.theminifo...e-wiring-guide/
Water pipes are simple and setup is very similar to an SPI mini.
Attached File  IMG_1666.jpg   69.6K   115 downloads
As for the exhaust manifold, this is stock at the moment without the cat, i just made a simple and horrible flat plate to convert to a normal single exhaust. i will get around to making a proper manifold, might be a turbo one though :-)
i will update as and when i get on further.
Edited by al_reidy, 01 August 2014 - 04:09 PM.
#2 l_jonez
l_jonez
  • 1,453 posts
Posted 01 August 2014 - 03:57 PM
Nice to see another build, also that all speed now do a 1.3 frame.
I originally did the same with the throttle cable but moved it as I wasn't happy with the location. You will probably find that even with the big washers the bulkhead will flex.
I had to mod the corrola manifold a bit but it did fit.
Keep up the good work I'd love to see that super charger on there!
#3 al_reidy
al_reidy
  • 351 posts
Posted 01 August 2014 - 04:04 PM
lets see, the clutch operation does seem to work, but without the engine running and something to power the wheels i can't tell.
Interesting that you did the same, i couldn't find any pictures of people doing it.
The supercharger looks like a nightmare to fabricate up an inlet manifold to match it, if i was to go forced induction i would go for a very small turbo like on the new 3cyl turbo engines ford do.
although its probably perfectly fine for me as standard to be honest.
#4 rids
rids
  • 670 posts
Posted 01 August 2014 - 07:38 PM
I've had no bother with this cable clutch set up
#5 al_reidy
al_reidy
  • 351 posts
Posted 01 August 2014 - 09:38 PM
I however can't weld, I have to borrow friends who can. So I tried to make something knowing my skill limit. Plus I wanted a normal center speedo and thought that the cable would cross the dash.
#6 evansisgreat
evansisgreat
  • 1,135 posts
  • Local Club: Not yet
Posted 09 August 2014 - 06:54 PM
In looking at the pictures, have you removed the inner wings? I'm just curious if you have to remove the inner wings to fit the allspeed frame.
#7 al_reidy
al_reidy
  • 351 posts
Posted 09 August 2014 - 10:03 PM
Yes the inner wings foul the frame :-(
#8 StewartB
StewartB
  • 93 posts
Posted 10 August 2014 - 08:31 AM
Following this closely as this is the road im away to go down, reliable motor with decent enough power output to keep me satisfied, and easily modifiable ;)
#9 smudger068
smudger068
  • 344 posts
Posted 10 August 2014 - 01:10 PM
I will be following this too
#10 Jones s13
Jones s13
    Just On Tickover
  • 5 posts
Posted 12 August 2014 - 05:24 PM
great thread! how would you rate the allspeed frame? I want a cg13 in my mini, but still weighing up my options as regards the frame, obviously I could home make a lot a cheaper, but then again the frame from allspeed looks very good quality and the idea of just bolting straight in is appealing
#11 al_reidy
al_reidy
  • 351 posts
Posted 13 August 2014 - 08:01 AM
The frame is very good quality, there are some issues i would like to mention:
- You really have to use allspeed bottom arms as the mounts are for rose joints, i did find a forum thread that said apparently minispares's rose joint kit will fit but they were out of stock.
 - The rear engine mount fouls the pot joint once you put a boot on it.
 - The rear engine mount replaces the Nissan one, which is fine apart from the nissan one did a vital role of also being the mount for the gear lever steady bar. So i had to weld on an extra strip of metal and bend it to as closer position as the original as i could, this could have been so much simpler  and very quick for them to do if it was already on the rear mount.
- As mentioned earlier up the thread, the inner arches. it seemingly would have been achievable to narrow the side braces in just 1cm or so to make it clear the inner arches. but you could always weld on some sheet metal back as an inner arch in as i will no doubt do.
- the brake pipe mounting tabs for the flexible's seem flimsy as they bend with little effort, also very high compared to standard. I've not seen an issue with it yet but it might be a little tight on full lock.
- it would have been nice to have a factory painted option like the other frames.
#12 malynch27
malynch27
  • 114 posts
Posted 13 August 2014 - 07:36 PM
Awesome thread so far.  Now following as this is deffo an avenue I want to go down.
#13 al_reidy
al_reidy
  • 351 posts
Posted 06 September 2014 - 02:41 PM
More work on attempting to get an inlet manifold to fit.
3" alloy pipe...
Attached File  IMG_1883.jpg   62.12K   49 downloads
Attached File  IMG_1885.jpg   68.03K   30 downloads
i got some 1cm thick plate that i drilled and cut to match the gasket of the throttle body.
Attached File  IMG_1886.jpg   111.37K   16 downloads
Attached File  IMG_1888.jpg   78.01K   31 downloads
I'm going to get it TIG welded up. i'll be back...
#14 BradleyRogerson
BradleyRogerson
  • 94 posts
Posted 15 September 2014 - 02:58 PM
looking good there matey :) your build is pretty much the exact same as mine except iv made my own frame although an allspeed one would have gone a treat, im on to the wiring with mine now, iv got it to turn over and power to the alternator but dont think my ecu is getting a live feed and now im just stuck :( :L keep us updated! :D
#15 lawrence
lawrence
  • 1,341 posts
Posted 18 September 2014 - 03:42 PM
This is all coming together nicely isn't it :) nice to see another Micra build although I am slightly jealous of your all speed frame
I also put my clutch cable through the top of the bulkhead
It works fine this way just need a bit of a file on the piece bolted to the bulkhead
Keep up the good work tho
Lawrence
