Gearbox Ball Bearing's
9 replies to this topic
#1 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 01 August 2014 - 07:46 AM
Hi
I stripped down my SC box last night to give it a clean out but as i was taking the main shaft out i noticed 2 small ball bearings in the bottom of the box as i lifted it out. I am guessing these have fallen out the syncro?
Full strip of the shaft to re fit them?
Nick
#2 GraemeC
GraemeC
  • 7,438 posts
Posted 01 August 2014 - 07:54 AM
If the main shaft is out, then you can strip it as far as the synchro hubs very easily (it'll almost fall apart), you don't need to mess with the locking pins of 2nd and 3rd gear.
If the balls are in the bottom of the case, hopefully the springs are still in the synchro hubs.  If not, they're readily available (and probably worth changing to be honest) - there's 3 balls/springs in each synchro.
#3 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 01 August 2014 - 08:12 AM
Cheers mate, hopefully the 3rd bearing and springs are still inside.
I'm right in saying its the hub on the far left that i lift off and it should have places for the bearings?
8473ABE8-27EA-46C4-8827-F2A5892AF34C_zps
#4 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 01 August 2014 - 12:30 PM
If you are keen you can refit the detent balls in place. But it's probably worth taking it apart now.
Edited by Stiggytoo, 01 August 2014 - 12:34 PM.
#5 Stiggytoo
Stiggytoo
    Best Plucker?
  • 1,170 posts
  • Local Club: CCMOC
Posted 01 August 2014 - 12:33 PM
And yeah, it's usually the 3/4th gear syncro hub that the detents erupt from. I would be worried if they came out while the gearbox was in use. This points to the selector detent possibly not being installed (in the diff casing)
#6 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 01 August 2014 - 01:15 PM
They just popped out when i was removing the roller bearings
#7 johnR
johnR
  • 2,297 posts
Posted 26 December 2017 - 11:37 PM
What's the trick to replacing the syncros - I'm struggling to get mine over the ball bearings?
#8 GraemeC
GraemeC
  • 7,438 posts
Posted 27 December 2017 - 07:52 AM
Patience, a 3rd pair of hands or one of the special tools (Guessworks sell one type, or Ive seen ones made from a jubilee clip)
#9 Spider
  • 14,851 posts
Posted 27 December 2017 - 08:37 AM
Here's a tool I made over 30 years ago and still use to this day;-
#10 RooBoonix
RooBoonix
  • 1,224 posts
Posted 27 December 2017 - 12:29 PM
It is do-able on your own, with your hands, I've done it. Very fiddly!
I love the simplicity and effectiveness of Moke's tool above though.
