Homemade Fly Wheel Puller
12 replies to this topic
#1 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 30 July 2014 - 07:50 PM
Being a tight arse I'm making my own fly wheel puller, to remove my pre verto fly wheel.
My question for you to answer or confirm is:
What is the thread size of the 3 bolts needed to screw into the fly wheel (is it 3/8" UNF)??
Cheers.
#2 M J W J
M J W J
  • 976 posts
  • Local Club: not yet
Posted 30 July 2014 - 07:55 PM
Something you might want to be aware of if you make your own puller. You will need a really fine thread for the bolt/ stud you wind in to put pressure against the end of the crank. If you use a normal ISO metric thread you won't get the mechanical advantage you need to pull the clutch off.
Like you I tried making one as it describes in the back of the haynes manual.  I sheared a few bolts, even an M16 with my own puller. I borrowed a proper one off a mate and the torque converter I was trying to remove came straight off. My dad and I noticed afterwards that the thread was much finer than the bolts we had been using.
#3 Cooperman
  • 23,278 posts
Posted 30 July 2014 - 07:56 PM
I have previously made my own using a piece of 3/4" thick boiler plate, some high-tensile 3/8" unf studs (Cylinder head studs with 3/8" UNC nuts welded on to the other end and spreader washers to get the correct position), and a BIG centre bolt, like 1" UNF thread.
#4 1984mini25
1984mini25
  • 8,784 posts
Posted 30 July 2014 - 07:59 PM
Its almost not worth making your own... for less than £20... http://www.halfords....flywheel-puller
#5 Cooperman
  • 23,278 posts
Posted 30 July 2014 - 08:04 PM
I broke one of those without really trying!
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 30 July 2014 - 08:11 PM
Four bolts £1.50 tops, bit of boiler plate, free or pack of biscuits to local steel stockholder, chance of breaking - Nil. Well worth doing. I have made a few for people now.
#7 Cooperman
  • 23,278 posts
Posted 30 July 2014 - 08:14 PM
I still have mine, although I also have another really strong one as well which I bought years ago.
The flywheel can be a b****r to get off.
#8 Doodling
Doodling
  • 260 posts
Posted 30 July 2014 - 09:26 PM
Where about did you spires your bolts from??
I like your idea for the center bolt thread cooper man , I was planning on using a M10 bolt.
Edited by Doodling, 30 July 2014 - 09:28 PM.
#9 M J W J
M J W J
  • 976 posts
Posted 31 July 2014 - 06:32 PM
Sheared an M10 straight away with mine, then an M12 and finally an M16.
If you do make your own then use a UNF thread as Cooperman says.
#10 A-Cell
A-Cell
  • 1,610 posts
Posted 31 July 2014 - 07:12 PM
Like Cooperman I have destroyed the Halfords supplied Laser make puller. Specifically the thread on the centre bolt whilst removing difficult Verto clutch type flywheels. I reckon you should bite the bullet and buy a heavy duty one from Guessworks! Save you a lot of grief and the wasted time making one. Have a search for the no of requests on here for help removing Verto flywheels.
http://www.guess-wor...play.htm?id=501
#11 L400RAS
L400RAS
  • 2,479 posts
  • Local Club: Lincolnshire Mini Owners Club
Posted 31 July 2014 - 07:38 PM
Minisports puller looks beefy enough, and good price.
#12 Alex_B
Alex_B
  • 4,573 posts
Posted 31 July 2014 - 08:07 PM
I have broken two Halfords pullers on one flywheel in the past, for me it was the three smaller bolts that failed, since bought a better puller for the same cost but it was second hand and looks much more up to the job!
#13 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 31 July 2014 - 08:21 PM
Guessworks puller has no equal!
It's dear, but so, so much better than the laser ones.
