I restored a 1989 998 a year ago installing two new looms (front and back) and rebuilding the engine as well as a new paint job and internal update. I set everything up and when going, the car runs sweet as a nut. The timing is set up OK, carb and mixture gives 35mpg. However, I have now blown 4 condensers, each one lasting between 2 and six months, with the car doing about 500 miles per month, to and from work. It is a 10-15 minutes job to change the part (I keep one now in the car at all times), but when in a suit, in the pouring rail it is a pain. I buy replacements (Lucas parts) from Motosave. Have I just got a bad batch or is there something in the ignition set up I am missing which causes these failures. Car is wired as a ballasted ignition with the correct coil.
Any ideas?
Haxeyman
