i seem to be loosing break brake fluid but ive had all the wheels off and there doesn't seem to be a leak... where else can i check?
Edited by Cooperman, 20 July 2014 - 08:37 PM.
Posted 20 July 2014 - 06:50 PM
Posted 20 July 2014 - 06:52 PM
Posted 20 July 2014 - 06:53 PM
Whip the drums and see if its collecting there, check all the lines to see if they look damp. And if you have a servo, check for white smoke out the exhaust, then check the vacuum tube for fluid.
drums i took of yesterday and they were fine just full of dust :) all the lines seem dry (bit oily and muddy i need to clean them one day) but no break fluid i haven't seen any white smoke and there isn't any when it starts up and where is the vaccum tube and how do i check?
Posted 20 July 2014 - 06:56 PM
Posted 20 July 2014 - 07:03 PM
check your carpets, if the master is leaking inside the car.
Posted 20 July 2014 - 07:07 PM
The vacuum tube will go from the carb/ manifold to the servo. Its usually a thin tube made of hard plastic with fatter rubber ends on. If the diaphragm in the servo breaks down, brake fluid can be sucked into the engine and burned.
nope not that :/
Posted 20 July 2014 - 07:08 PM
its all fine in the car all dry and not destroyed
Posted 20 July 2014 - 08:24 PM
Edited by cal844, 20 July 2014 - 08:25 PM.
Posted 21 July 2014 - 09:35 AM
Posted 21 July 2014 - 09:38 AM
Posted 21 July 2014 - 09:45 AM
If you replace a master cylinder, try to bench bleed it before fitting. Works on old mustangs
Posted 21 July 2014 - 12:31 PM
take the rear drums off and inspect the brake cylinders. lift the rubber gaitors to check for leaking fluid.
Posted 21 July 2014 - 01:59 PM
I'd be seconding the possibility of the MC leaking into the Servo. You might not be getting any white smoke yet because it hasn't full up the servo enough yet to reach the vac pipes. It happened me before.
Posted 21 July 2014 - 02:32 PM
Yep, I'll second this. I had a loss of fluid on my Mini and kept topping it up until I found the Servo to be 1/4 full of the stuff.
