Power File - North Devon Area
6 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 12 July 2014 - 06:34 PM
Hi;
I have a couple of welds that I need to dress down but I cannot get to them. They are in the front of the Subframe in the recess where the Radius Arm Fits and I don't want to leave them and paint only to find they are in the way when I do the rebuild.
Does anyone have a Power File that I could borrow or know where I could get this dressed down for a small charge or free.
I don't really want to buy one as I won't get much use out of it and its project money that I have not factored :-(
Thanks for looking
Edited by JonnyAlpha, 12 July 2014 - 06:34 PM.
#2 the_samkingdon15
the_samkingdon15
    formally known as samkingd0n
  • 644 posts
  • Local Club: I ride alone
Posted 12 July 2014 - 07:10 PM
Hi;
Thanks for looking
I can ask at work tomorrow if my uncle has one.. if so, we are in South Molton
#3 rogermini50
rogermini50
  • 22 posts
Posted 12 July 2014 - 09:58 PM
hi you could use a carbide bullnose burr.if you can get access with a drill you should be able to do it but be careful they do take a lot of material off,you can get these of ebay  (ps wear safety goggles when using them)
#4 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 12 July 2014 - 10:34 PM
Thanks Sam, i'll wait out?
#5 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 12 July 2014 - 10:49 PM
Like these have you had success with them? I would need one with a longish shank.
#6 rogermini50
rogermini50
  • 22 posts
Posted 13 July 2014 - 07:18 AM
Yes i do use these they are handy to have in your tool box i just measured one of mine and it's 63mm end to end but you will need to have at least 12mm into the drill chuck. i have extended these b4 but you need a tig welder and v- block 6mm bar,  You can buy longer shank ones on ebay ,
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 13 July 2014 - 07:20 PM
I popped into town today and found these in B&Q (nothing in Wikes or Homebase), no Burrs anywhere:
Not being a fan of stones I opted for the Rotary Files, I thought being Bosch they should be OK:
Anyway here's the result:
Plenty of metal removal and I also removed the ledge at the bottom but forgot to take a Photo. They didn't wear down that much either so will be good for a few more goes if I need them.
Job done, nearly ready to paint, just need to finish welding tomorrow, then prime, then top coat.
Edited by JonnyAlpha, 13 July 2014 - 07:22 PM.
