how do I check to see if I have play in the diff
and what is ok and not, to see about this movement I have on / off the throttle
as if the subframe or engine mounts have gone which seem all ok
Posted 10 July 2014 - 09:12 PM
Posted 10 July 2014 - 09:30 PM
Jack the car up on one side and see how much free play you have in the raised wheel with the car in gear. You will soon know if this is a problem.
If there is a lot of free play, remove the engine & gearbox, take off the diff cover, remove the diff unit and look at the pin. If it is worn, fit a X-Pin diff and the problem is solved.
Posted 10 July 2014 - 10:07 PM
Some more info:
http://www.theminifo...ferential play
Posted 11 July 2014 - 08:25 AM
yes I did that but don't know what is exceptable or not it was 50mm both sides in first gear
Posted 11 July 2014 - 06:19 PM
looks like something in the diff not right
will take engine out have alook
Posted 11 July 2014 - 06:41 PM
Posted 11 July 2014 - 08:35 PM
lol
Posted 12 July 2014 - 10:17 AM
got drive shaft and pot joint out from drivers side and the shaft from the diff
has about 3/16 play up and down and sideways
so engine coming out,
DO I REALY NEED A CROSS PIN DIFF OR WILL A MOLY ONE BE OK FOR WHAT I NEED
ONLY GOT 75 HP AND 80 TORQUE JUST SEMI FAST ROAD UP THE LANES, NO RACING
LIKE THE OLD DAYS
ALSO WHAT POT JOINT BEST THE MINISPARES £28 or £37
Posted 12 July 2014 - 11:07 AM
What kills the diff pin is long final drives ( eg MPi's ) or lifting a driving wheel (wheelspin), so if you're into spirited driving then I would suggest an x-pin... it's a belt and braces replacement, but you must buy the correct type, too many times I've had to rebuild some cheaper x-pins which have come across my bench because substandard quality parts have been used, namely the pins, and they've worn and taken out the thrusts and planets too...
The moly pins are good, I use them as standard in my rebuilds and are fine for every day cars.
