Sequential Gearbox?
#31
Posted 07 July 2014 - 07:38 PM
There are cheaper, lighter, more powerful and higher revving engines out there that are easier to find parts for.
#32
Posted 07 July 2014 - 07:42 PM
#33
Posted 07 July 2014 - 07:43 PM
#34
Posted 07 July 2014 - 07:44 PM
#35
Posted 07 July 2014 - 07:45 PM
#36
Posted 07 July 2014 - 07:47 PM
#37
Posted 07 July 2014 - 07:52 PM
#38
Posted 07 July 2014 - 07:55 PM
#39
Posted 07 July 2014 - 08:01 PM
if you are running inline then you've more chance of getting a sequential box cheaper.
#40
Posted 07 July 2014 - 08:10 PM
Go for a 1275 A+ from a Morris Ital, or a pre A+ 1275 from the MG Midget or Morris Marina, if they haven't all been taken by the MM (Morris Minor) folk.
I wouldn't use the MM gearbox as it's not very strong and soon expires when the power is upped, there are conversion kits for Ford RWD gearboxes.
#41
Posted 07 July 2014 - 08:29 PM
#42
Posted 07 July 2014 - 08:41 PM
Were you thinking of longitudinally mounting a transverse (Mini) engine? When there's a version available that is designed for inline applications?
What car is this going in?
What exactly are you trying to achieve?
#43
Posted 07 July 2014 - 08:48 PM
harry, i am trying to achieve madness more or less. the project thread is going up tonight of my plans, and itll reveal all, its too complex to explain here, and ill probably be hated by everyone on here, but hey, its my life so i will do what i want.
the basic idea is to run it to a rwd setup. but because of the shape of what its going in, it would have to be inline. didnt realise until today that other cars used the same engine (sorry, first car and all, learn by doing, not reading.). so it would be run kind of like a porsche, mid engined, rwd (not a porsche fan, but this was a cross bread idea by me and my friends. so its all gone a bit pear shaped) anyways, all will be revealed soon! ill post the link here asap :)
and its not going in a pre built shell, thats more or less all the hints im gonna give atm
#45
Posted 07 July 2014 - 10:12 PM
You definitely won't get a Mini engine to run longitudinally, but the A-series has been used longitudinally in many cars from the A30 and Morris Minor through to the Austin-Healey Sprite/MG Midget & Morris Marina/Ital.
Assuming your budget is large, which it will need to be for any sort of radical project, you could mate that to a good 5-speed auto box with full manual over-ride and select a diff and the FDR to suit the application.
It will require a lot of engineering design to make the interface work, together with calculations in respect of overall gearing, but for the right money it would be relatively straightforward.
A 1275 A-H Sprite/MG Midget engine, bored to 1330 cc, can easily give over 110 bhp. Maybe a 5-speed auto box from a small BMW would be good, although how it could be connected electronically to the engine characteristics might be a problem. Earlier boxes which are mechanically controlled will probably only be 4-speed (from a 1980's BMW 318i maybe).
Edited by Cooperman, 07 July 2014 - 10:12 PM.
