Sequential Gearbox?
84 replies to this topic
#16 steah
steah
  • 109 posts
  • Local Club: none yet
Posted 07 July 2014 - 07:21 AM
Just googled it... like a 'tiptronic' I believe?
#17 The Matt
The Matt
  • 17,232 posts
  • Name: Matt
Posted 07 July 2014 - 11:08 AM
Can I ask why you want a sequential box?  I mean, what do you see as the main benefits and why do you see it as being necessary for your build?
#18 mab01uk
mab01uk
  • 12,522 posts
Posted 07 July 2014 - 11:53 AM
Thanks guys, but jeez the price! Had a thought last night while I was using my lego to model e sequential box, would it not be possible to just convert an auto to where it was more, semi auto? So you controlled when it changed but it did the work? Just a thought? Tell me if thats a stupid idea? So its not necessarily a sequential, but it works in a similar fashion with regards to user input? I.e, you press a paddle to shift up, and another to go down?
The Mini Automatic can be shifted manually through all gears as standard, so you can already control when it changes yourself via the lever. When it was introduced in the 1960's few other autos allowed this option for clutchless manual gear shifting.
#19 steah
steah
  • 109 posts
Posted 07 July 2014 - 12:38 PM
The matt: the reason I want a sequential box is because the car will be 95% track oriented, and on top of this, its not in a mini shell, its an a series based track day thing, based on an a series cause I understand it and know what iI'm doing? So thr sequential box is a good idea because the engine won't be mounted in a usual manner, it won't be sideways, itll be straight.
#20 steah
steah
  • 109 posts
Posted 07 July 2014 - 12:42 PM
!Mab01uk: so it would be possible to attach a chip to control this via paddles then?
#21 Badboytunes
Badboytunes
  • 1,615 posts
  • Local Club: MINIS Unleashed
Posted 07 July 2014 - 12:45 PM
I would say no as it is not an electronically controlled box. I may be corected tho if im wrong.........
#22 steah
steah
  • 109 posts
Posted 07 July 2014 - 12:55 PM
Well maybe a servo then? Ill look into it thanks
#23 cian
cian
  • 869 posts
  • Local Club: Minis In Northern Ireland
Posted 07 July 2014 - 03:19 PM
Your bound to knacker the brass selector forks and syncros would have to upgrade all these and that would be pricey
#24 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 07 July 2014 - 03:44 PM
You do realise there is already an A series for jnline mounting , used on Morris Minors etc.
Would be a load of unneeded hassle to try and convert a Mini A series (transverse) to be mounted inline.
#25 Tomm
Tomm
  • 2,462 posts
Posted 07 July 2014 - 04:37 PM
Afternoon
Do you know how much the motorbike internals conversion would be roughly? Cheers in advance
It is not so much a questions of money, a heck of a lot of knowledge and personal experience is involved in such a project. Matty, the chap who has built the gearbox has put a tonne of time, effort, research and money into the project, he has had trouble with some of the machining work as well I believe because he is working on such a bespoke basis.
It's an amazing feat from my standpoint and is an absolute phenomenal accomplishment on his part as far as I am concerned.
Unfortunately it's not a "how much" kind of question.
Not quite, triptonic is effectively like a semi auto whilst leaving the driver in control of the gearbox the clutch is all taken care of. Various manafaturers use various names, BMW call it SMG, Audi call it DSG but as far as I am aware it all works on the same basis.
I have a DSG equipped Audi, it's the most fun I've ever had. If you get chance to drive one, take them up on the offer.
#26 HarrysMini
HarrysMini
  • 3,352 posts
Posted 07 July 2014 - 05:30 PM
With this, the driver is never fully in control of the gear changes.
We had a DSG equipped Golf and it was just simply superb. You could hardly tell when it was changing gear. But when you put it into manual mode, it would still change up and down for you. This is what eventually lead us to swapping it for a manual MINI.
I don't have much experience with sequential gearboxes, but I guess they are semi auto? I would also assume it leaves all of the gear changing to the driver, rather than changing up as soon as you reach the red line.
#27 Tupers
Tupers
  • 4,156 posts
Posted 07 July 2014 - 06:34 PM
I doubt you could get one done for any less than £10K. Unless you're recently won the lottery or have an insanely good job for a 17 year old I'd stick to a Mini Spares straight cut gear kit.
#28 Artful Dodger
Artful Dodger
    " I AM THE SPECIAL ONE"
  • 4,435 posts
Posted 07 July 2014 - 06:46 PM
its alot of money for a pointless upgrade. you will be forever rebuilding it doe to worn out dog rings and its sich a tiny gain if you were on track with it.  poooiiinnttleessss!! spend 5-6 grand on an engine instead
#29 steah
steah
  • 109 posts
Posted 07 July 2014 - 07:03 PM
The idea is to run a mini a series. We are on a tight budget, this was only an idea, if it can't be done within about 2k I wont do it, it was just an idea. Cheers guys, keep an eye out for my project thread, should appear within 2 days with my plans :)
#30 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 07 July 2014 - 07:35 PM
so you want to run an a series inline?
