I just did my rear cylinders using this method, it works pretty well and makes those annoying clips that bit easier to put on. I had to use a mallet on one of the brake lines to get it to engage with the thread on the new cylinder but once that part was done it was straightforward enough
How To Fit Rear Wheel Cylinders, The Shifty Way!
#31
Posted 06 April 2017 - 07:33 PM
#32
Posted 31 July 2017 - 03:42 PM
Wish I had come up with this before, good tip!
#33
Posted 02 March 2020 - 06:46 AM
I gave up with the clip that came with my cylinders and used halfords ones which took 3 seconds to fit!!
#34
Posted 02 March 2020 - 06:47 AM
#35
Posted 20 June 2020 - 05:30 PM
Here is a good video showing how to do the circlips with just a small flat blade screw driver and a little tapping from a hammer....also note use of adjustable clamps to hold the cylinder...but the "Mole"/Vicegrips method from the OP is also good.
#36
Posted 21 June 2020 - 05:48 PM
Never to be seen again.....
Next time no swear words.....
Promise....
#37
Posted 21 June 2020 - 07:18 PM
This was a great help. Between the vise-grips tip and this video clip I had very little trouble fitting the clip. Thanks all!
#38
Posted 02 July 2020 - 06:15 PM
I spent the $20 bucks for the BMC tool. Don't know why I didn't think to use common circlips.
Edited by Rosebud, 02 July 2020 - 06:28 PM.
#39
Posted 26 July 2020 - 07:40 PM
I just did the cylinders for the first time myself and had no real issues, used the vice-grip setup to hold the cylinder in place as shown in the video. Little flat blade screwdriver and light hammer taps got it all home. . Some tips that helped me....I tried to prevent fluid loss using a rubber glove finger and rubber band to make a condom over the released pipe...though it worked it made big mess as I struggled to get the "glove" into place. Haynes says to clamp the flex hose to reduce loss...and I ended up doing that. It worked much better...just be careful to protect the rubber hose from damage by wrapping it with some paper towel etc where the jaws of a vice grip will contact. Doesn't need much force to seal.
#40
Posted 26 July 2020 - 07:42 PM
I just did the cylinders for the first time myself and had no real issues, used the vice-grip setup to hold the cylinder in place as shown in the video. Little flat blade screwdriver and light hammer taps got it all home. . Some tips that helped me....I tried to prevent fluid loss using a rubber glove finger and rubber band to make a condom over the released pipe...though it worked it made big mess as I struggled to get the "glove" into place. Haynes says to clamp the flex hose to reduce loss...and I ended up doing that. It worked much better...just be careful to protect the rubber hose from damage by wrapping it with some paper towel etc where the jaws of a vice grip will contact. Doesn't need much force to seal. For bleeding the cylinders afterwards, I used the old school method of gravity bleeding. A bit of hose on the bleeder and a jar, open the bleeder and let it drip slowly for 10-30 minutes, watching/topping up reservoir level. Tighten the bleeder, done. No fancy vacuums or pumps needed.
#41
Posted 31 July 2021 - 08:15 PM
#42
Posted 14 June 2022 - 08:02 PM
The proper clips are efffectively springs that hold the cylinder tight against the backplate
#43
Posted 26 May 2024 - 10:32 AM
I use a pair of circlip pliers to fit the clip over the cylinder, and then a small screwdriver to lever the clip into the groove.
Never had a problem doing it this way, and I tend to do it after I have fitted the line.
