How To Fit Rear Wheel Cylinders, The Shifty Way!
42 replies to this topic
#16 Shifty
Shifty
    Sponsored by Fosters (tm)
  • 13,157 posts
  • Name: Sean
Posted 25 June 2015 - 10:12 PM
Must be the browser....I had a look at home and can see it....not here at work, oh well.
So the vise grip (mole ) is really just pushing against the cylinder then.......the tricky bit is those damn clips
They are much, much easier to do with the mole grips.  Trust me on this, once you've tried it this way you'll never go back
#17 MiniKermit
MiniKermit
    The list master!!
  • 608 posts
  • Local Club: Rusty Flange Club
Posted 07 July 2015 - 06:25 PM
I can see the benefit with this method, they were a ******* on Bertie this weekend!
#18 Patriot
Patriot
  • 125 posts
Posted 12 July 2015 - 08:46 PM
Great advice.
Just fitted new cylinders today using the tip.
Made it easy.
#19 Spitz
Spitz
  • 1,716 posts
Posted 14 July 2015 - 07:03 PM
So I used this tip on the rear cylinders of a Midget.
Great idea, and held the cylinder in place nicely.
The only problem is the clip.....OMG....I don't remember having this much problem with them in the past.....although it's been a while.
Luckily, one side I could use the original type of ring clip that was on the Midget....the other side broke, so had to use the horrible clip....aaaarg
#20 floormanager
floormanager
  • 804 posts
  • Local Club: Mini Club Sussex
Posted 21 January 2016 - 08:29 PM
Hi all,
The photo has disappeared again - anyone know how the mole grips hold the rear cylinder in place while you fit the circlip?
Thanks,
Paul
#21 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 21 January 2016 - 08:35 PM
It pushes the cylinder into the back plate hole .. It clamps over the top ... If you can visualise that until the pic returns
#22 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 January 2016 - 08:53 PM
nah....in shiftys orignal pics, it shows it clamped to the hub and the edge of the mole grips holds the cylinder in place.
#23 gazza82
gazza82
  • 3,099 posts
  • Local Club: TMF+
Posted 21 January 2016 - 08:59 PM
My bad ... I knew it clamped downwards ... Wrong bit of metal :-(
#24 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Attached File  10449937_10153123571164119_2706924390086164558_n.jpg   56.01K   41 downloads
#25 ukcooper
ukcooper
  • 1,625 posts
Posted 21 January 2016 - 09:01 PM
#26 Shifty
Shifty
  • 13,157 posts
  • Name: Sean
Attached File  10449937_10153123571164119_2706924390086164558_n.jpg   56.01K   23 downloads
Added the picture again
#27 floormanager
floormanager
  • 804 posts
Posted 21 January 2016 - 09:07 PM
Oh I am so impressed!!  what a clever idea.  I was trying to work out how you managed to get the jaws of the mole grips around the wheel cylinder.  Thank you to all, that is so clever.
#28 Spitz
Spitz
  • 1,716 posts
Posted 25 January 2016 - 04:29 PM
ukcooper.....what is that cone you are showing...is it a special tool, or an improvised one?
#29 GraemeC
GraemeC
  • 7,476 posts
Posted 25 January 2016 - 04:38 PM
Edited by GraemeC, 25 January 2016 - 04:40 PM.
#30 Steve-O 2014
Steve-O 2014
  • 312 posts
Posted 15 January 2017 - 08:41 PM
Thanks, just used this method yesterday
To get the annoying clip on I bent one side up at the opening, wedged the other side and the center in the groove and put a socket over and wacked it and it popped the loose / bent side on :-) oh and removed the bleed nipple to make it easier
Edited by Steve-O 2014, 15 January 2017 - 08:41 PM.
