Intermittent Tone (Beep)
Posted 22 June 2006 - 03:09 AM
Posted 22 June 2006 - 10:22 AM
Posted 22 June 2006 - 12:15 PM
Anyone have a late 90's owners manual that might list the warning lights and sounds?
Posted 22 June 2006 - 04:15 PM
Posted 22 June 2006 - 06:00 PM
What sort of noise is this?
The best description I can come up with is that it sounds like the short tone/beep you hear when you first turn the ignition key to the ON position (but of course longer)...
Posted 22 June 2006 - 06:05 PM
Hmmm, I am unfamiliar with them too, but is it the fuel pump buzzing in the boot when you turn the ignition on??
Posted 22 June 2006 - 08:29 PM
So its definitely an electronic beep?
Posted 23 June 2006 - 02:29 AM
Yes, it's definately electronic. I took it out again tonight and it did it a couple of more times and then all was quiet. After replacing the O2 sensor and vac line I also reset the ECU so maybe that has something to do with. Do the ECUs emit any beeps when they're in learning mode?
Posted 23 June 2006 - 11:42 AM
I don't understand what you mean about the short beep when you turn the key either. Do you have the standard immobiliser and alarm?
Posted 23 June 2006 - 12:43 PM
I had a 95 SPI for a while, never heard any beeps! Can you work out where it is coming from at all? Front, rear, engine bay?
It's coming from the dash (or rather behind it). It's always sounds a short electronic tone when the ignition key is turned to the on position. I always assumed that all "newer" SPI/MPI minis did that (I also have an 1986 1000 Std w/ Carb setup which doesn't).
I don't think I have the immobilizer and alarm as the car didn't come with a key fob (of course I bought it used). I'll have to see if I can find a post on the location and check. But would the car start without the fob if the immobilizer and alarm is installed?
Maybe it's something specific to the Japanese version? Anyway, I drove it to work this morning, about 35 miles, and no more beeping!. So maybe it's happy again... B) Thanks again for the help!....
Posted 29 June 2008 - 01:08 PM
Posted 29 June 2008 - 01:54 PM
Posted 29 June 2008 - 03:33 PM
Posted 29 June 2008 - 08:24 PM
Could it possibly the Cat sensor? My Jap-spec Mini has the red warning light labeled "EXH" to warn about the exhaust gasses running through the cat. It seems likely that in the later jap-spec model, a beep has been added to the warning light...
Thank You!... Turned out that someone must have replaced the CAT sensor in the past and simply twisted the wires together.(at least I hope it's not done that way at the factory!).....A little solder and heat shrink quieted the beeping. Thank you very much for the help!......
