Map sensor blocked ?
That's one I've had before. Sooted up like crazy.
Posted 27 June 2014 - 07:53 PM
Posted 27 June 2014 - 08:11 PM
Posted 27 June 2014 - 08:29 PM
Posted 28 June 2014 - 06:25 AM
Take the MAP sensor out and see if it's clogged up mate. Mine was, I had already bought a new one as I flashed a code and it diagnosed a faulty map sensor reading. i went to fit the new one and noticed there was a load of crud in the MAP sensor, cleaned it out, refitted it....hey presto. I still fitted the new one anyway, but it's definitely worth giving it a clean out.
Posted 28 June 2014 - 06:28 AM
The other thing worth mentioning is that you can get the code readers DIRT cheap now. I bought a Tech2 one for Vauxhall/Opel when I had a Vectra, but you can get universal readers off ebay or amazon for 15 quid.
The Tech2 was good though, as you could control all the body functions (even sit there and control the wipers and horn) through the laptop. The cheap ebay/amazon readers will only give you a fault code. Not sure if you can reset them like you can on the Tech2.
