cheers man, they were 13" austin healy sprite steelies which are getting pretty hard to find. dooo iiiit!! 12s will look sweet! to be honest anything banded will
The Stanced Fast Road Thing.
#46
Posted 13 October 2014 - 08:33 PM
#47
Posted 14 October 2014 - 09:45 PM
Majestic boxes arrived from various mini retailers. hardened steel drive flanges, full negative camber kit from minisport with polly bushes, and some fresh arches to paint up.
Great adventure awaits.
#48
Posted 15 October 2014 - 05:03 PM
sweet, which arches did you go for?
#49
Posted 15 October 2014 - 09:28 PM
Huddersfield's group 6, practically group 2 wides. Decided to go for them since i wont have to drill different holes. I might widen them myself.
Also found a set of 12" steels which should arrive tomorrow, will use them for winter and trim my current arches to suit, then i'll get them banded to 7" rear and 6" fronts.
What size studs did you use for your steels? Since the mounting faces aren't very fat. currently for my revolutions im having to use the 78mm long studs just so i could get around 20mm thread engagement.
Edited by Yams, 15 October 2014 - 09:30 PM.
#50
Posted 15 October 2014 - 10:38 PM
sounds good mate, steelies will look awesome. yeah those are the ones im using but im using steel wheel nuts that are slightly different. i needed the longer studs for the 9mm spacers im running on the back
#51
Posted 15 October 2014 - 10:42 PM
#52
Posted 16 October 2014 - 09:41 AM
yeah that was my plan, but i left the spacers on anyway for some mad poke lol... here ya go mate
http://www.ebay.co.u...=STRK:MEBIDX:IT
#53
Posted 16 October 2014 - 09:16 PM
Steels delivered. Shame my photography skills haven't.
Not sure whether to have the banded before or after winter. I'm thinking before, since i don't want to be seen running group 2 wides with skinny overached grubby steels.
Edited by Yams, 17 October 2014 - 02:00 PM.
#54
Posted 09 January 2015 - 09:08 PM
Started work on the winter wheels. Perhaps a little late but, but been busy. Looking at the picture you probably think the prep is aweful, however the wheel on left had been wire-brushed, sanded, rust treated and de-greased. This is a very initial light coat of standard red primer before i moved on to the 'beige' hammerite anti rust stuff. The wheel on the right is how they looked after around 3 goes with nitromors.
After the second coat of Hammerite primer. It covers pretty well but it takes an age to dry. Made the mistake of flatting it back a little too early which was a set back. Only managed to get this far today, and the weather wasn't too great. the wheels also took way more wire-brushing than expecting. Hoping to get them all done over the weekend.
I'm taking my time with the prep, as i want them to look good through the winter, and as soon as i take them off they'll be going to get blasted, banded and powder coated.
<- Still wet, this isn't the final colour!
Also had /done a few more things over the past few months that i simply haven't had to to upload, so i'll update that also. Just stuff like camber brackets etc.
Edited by Yams, 09 January 2015 - 09:10 PM.
#55
Posted 10 January 2015 - 06:02 PM
#56
Posted 14 January 2015 - 08:42 PM
#57
Posted 14 January 2015 - 09:58 PM
those look epic! whats happening with the arches? you running these with them?
#58
Posted 15 January 2015 - 07:28 AM
Cheers man. Think my current arches (ones which have been friction burnt) I will fix and paint black again, and the new wide arches which are the same will be painted same colour as the body. I'll buy some standard group 2s to cover these hideously skinny wheels until its warm enough to use the revolutions while these steels get banded. The steels arn't fitted yet, need to perfect how the caps fit to the wheels, and need to put the studs for them into my new hubs. Hopefully i'll have a pic with them on over the weekend.
Not had snow down my end yet, but im sure it wont be long now!
#59
Posted 08 July 2015 - 08:30 PM
Fresh arches. Thats all.
#60
Posted 08 July 2015 - 09:36 PM
nice, whats the plan to stop them getting burnt through like the last set? stiffen up the shocks?
