Hey guys my brakes have started to play up when I press the pedal there is nothing there, then the pedal seems to give all at once and then the brakes are on sharp , I was doing 60 earlyer and pressed on my brakes and there was practically nothing there . Its an 89 so servo'd with braided hoses any advice would be great
2 replies to this topic
Posted 11 June 2014 - 09:30 PM
Posted 11 June 2014 - 09:51 PM
First off, DON'T DRIVE IT.
Sounds like a master cylinder fault or possibly the FAM7821 valve but start off with a proper inspection of everything. Check the callipers for corrosion around the pistons and general condition. Is it losing fluid?
Posted 11 June 2014 - 10:21 PM
Calipers are all sound , fluid level has dropped a little bit but I think thats due to pads wearing e.t.c to be honest it does point back to the master cylinder
Also tagged with one or more of these keywords: brakes
Mini Technical Sections →
Problems, Questions and Technical →
Is It Easy To Swap Post 84 Drums To Pre 84 Drums?Started by Daniel Watkin , 03 Aug 2024 brakes |
Dunlop D1 Fitment And InstallationStarted by Mrhydro , 18 Jul 2024 brakes |
Brake Cylinder Reservoir Cap.Started by OJDee , 15 Jul 2024 brakes, electrical |
Brake Pedal Relocation?Started by tommyboymini , 08 Jul 2024 brakes |
Cutaway Section View Of 7.5" Cooper S Caliper?Started by sandman , 01 May 2024 brakes |
