I am surprised nobody has mentioned thread locking compound. With a semi removable / medium strength thread compound, it helps with torque down, prevents corrosion, holds the fastener against vibration and also allows you to remove said fastener when you want; it also wont run out when the part warms up. I have a range of thread locking compounds that i use for different fasteners around the car. I pretty much save copper grease for behind brake pads only
I mentioned it. All but a few bolts have either got CS or a thread lock on them. There are not many bolts that go on dry on my car.
