Hi;
When I refit my Subframe I have read that it is good practice to use Copper Grease on the Mounting Bolts to prevent corrosion.
I am also cleaning up my Radius Arms and Hubs and the Haynes Manual says to apply High Temp Grease to the moving parts of the Brake Shoes and Backplate, the picture in the manual is Copper Grease?
So assuming that there is only one type of Copper Grease (This Stuff) I'll be using it as follows:
1. Rear Sub Frame Mounting Bolts (Captive Nuts in the Heelboard)
2. Moving Brake Parts.
Question:
When refitting the Brake Pipes and Hoses can copper grease or any other long lasting lubricant be used in the brake union nuts, the ones that secure the Copper Pipes to Brass Unions and Flexible Hoses? Or is there a possibility of it contaminating the brake system? The reason I asked is because some of these where corroded when removed?
Should it also be used around the nuts and threads that hold the Brake Unions and Pipes to the Subframe / Radius Arm Brackets is should these just be greased with some other type (if so what)?
