Hi Everyone,
STORY (for technical details skip this)
A year ago in Japan when staring the car on the way home from work, the engine would turn but not continue run. I later found that there was no power going to the pump.
With the key in the "on" position, there was no 'whir' of the pump priming the fuel system. I thought I was stuck. That day I took the train to work.
When I got home, tried to fire up the car, heard the 'whir' and she started right up. Weird, I thought.
Problem went away, then came back a few months later. Same thing. Brought it to the shop, they couldn't find anything.
Now just a couple days ago, after driving around town for about an hour, park it, went to dinner, when we came back, it happened again. Left the car there thinking if we waited overnight that it would work (as we have done in the past), came back the next day still nothing.
TECHNICAL
Searching around different forums:
I've realized the 4 main points of failure could be:
- Fuse (glass)
- Inertia Switch
- Relay Box
- Wiring (purple/slate color)
So far:
- I've checked the fuse (10A), it was blown. I quickly replaced it, still nothing. What blew the fuse? (Fuse holders and fuses were replaced with new ones just a few months ago.)
- I've checked the inertia switch and it's in, not popped up.
- I've connected a fused link directly between the battery and the posi+ive terminal on the pump and the pump sounds just as good as usual.
After directly running a wire directly from the battery to the pump, drove the car home without any problems. Strange thing to me was that after unplugging the wire while the car was running, the pump still ran under it's own power. I decided to turn off the car and then turn on the car again, and she fired right up without the wire. So to me it seems like it's still getting power. I'm going to try to fire it up again without the wire tomorrow in the morning to see if the problem persists. What I'm worried about is that it'll work fine again and I won't be able to find the point of failure.
Next up will be the relay box however I'm worried because I understand the pinouts are different for the Japanese-spec Minis with A/C compared to the "Pinned" post on this forum. Also will check the wires.
What are your suggestions? Any idea what might've blown the fuse?
I've owned my Mini for 3 years now, and just recently imported to Vancouver, Canada. There are lots of Mini shops in Japan so every time I've had a problem and couldn't figure it out myself, just popped it by the local Mini shop and got it fixed quick. After moving here... I have no idea who to bring it to so I am hoping to find some more specific advice with this post.
Thanks so much.
