Doug
By feel I did mean that it is too hot to touch. But if you say this is normal then I am not over concerned. I had thought if it was far too hot to touch then it must be far too hot in the engine and is therefore overheating.
So from what you have said I might not have to worry too much about the heat. Regardless I would like to make sure the temp gauge is working correctly and get it sorted.
Ive ordered 2 different senders now so I will try them and if they don't work I may need to stat looking at measuring the temp to determine if what you are saying is happening that the engine may feel hot but might still not be hot enough to be showing on the gauges.
Thanks for your help, hopefully Ill get it sorted soon.
