Yay, Got The Oil Temp Gauge Sorted..
60 replies to this topic
#46 fergiemike
fergiemike
  • 36 posts
Posted 17 February 2015 - 11:20 AM
Well mine has 2 pins but only one is connected and it earths through the engine maybe you can run an earth from the other pin or from the metal part of the sensor that goes into the adaptor
#47 bloke
bloke
  • 139 posts
Posted 17 February 2015 - 08:03 PM
You'd have to ground the metal (brass colour) part of the sensor to something metal, as said above, on the engine. It's possible to solder to it after a fashion, if you have a soldering iron. Making the adaptor out of aluminium is a bit silly on their behalf, it's not conductive. The other pin is not connected to anything, both at the plug or socket.
#48 jamesquintin
jamesquintin
  • 1,025 posts
Posted 18 February 2015 - 09:46 AM
So has anyone on here actually got the SC part and its working as intended..?
Q
#49 ukcooper
ukcooper
  • 1,625 posts
Posted 20 February 2015 - 03:34 PM
Nope mines still sitting the draw of parts to be fitted..
#50 jamesquintin
jamesquintin
  • 1,025 posts
Posted 23 February 2015 - 10:05 AM
Right!
Finally got it working... SC sent me an extra cable to fit into the sensor connector
I took the rubber seal off the connector. There was a load of rubber sealant in the hole, so I had to prise that out before I could slip the pin in
I earthed the cable using the earth for the radiator fan. (the tape on the live is from a bodge an AA man did years ago to get the fan working after I overheated)
This is how it looks in the car now, and the gauge is working!
Hurrah
#51 FlyingScot
FlyingScot
  • 2,676 posts
Posted 23 February 2015 - 12:16 PM
Good that it's working, although looks a bit of a bodge from SC.
I wouldn't be happy with it, I would have expected they took it back and sorted it, seems a bit of an oversight on their part not knowing the connection details....
FS
#52 jamesquintin
jamesquintin
  • 1,025 posts
Posted 23 February 2015 - 03:03 PM
they said they've sold a load, but if they are just sitting in peoples drawers... ;)
#53 bloke
bloke
  • 139 posts
Posted 17 April 2015 - 08:12 PM
Now even Minispares are at it. :-)
#54 FlyingScot
FlyingScot
  • 2,676 posts
Posted 17 April 2015 - 08:24 PM
Actually looks a better solution http://www.minispare.../YCB100320.aspx
FS
#55 bloke
bloke
  • 139 posts
Posted 19 April 2015 - 11:47 AM
Sadly that's just a picture of the old one, which is now discontinued, they just haven't put the new photograph up yet.
#56 brivinci
brivinci
  • 1,225 posts
Posted 25 June 2015 - 08:54 PM
Is Mini Spares using the same MGF sensors as the OP used in this?
I am still after installing a oil temp gauge on my SPi. I currently have the magnet adapter that bolts to the back of the sump where the oil pickup pipe bolts to. Thought it would be a perfect place for a sensor as most say that the magnet isnt a great idea there. Wondering what the threads are on the sensor and/or adapter, and if anyone knows where one could find a new/used harness (the female plug part) that plugs into it?
Edited by brivinci, 25 June 2015 - 09:06 PM.
#57 PlugExploits
PlugExploits
  • Just Joined
  • 137 posts
Posted 25 June 2015 - 08:58 PM
I am still after installing a oil temp gauge on my SPi. I currently have the magnet adapter that bolts to the back of the sump where the oil pickup pipe bolts to. Thought it would be a perfect place for a sensor as most say that the magnet isnt a great idea there. Wondering what the threads are on the sensor and if anyone knows where one could find a new/used harness that plugs into it?
Look at this.
http://www.theminifo...view=getnewpost
#58 jamesquintin
jamesquintin
  • 1,025 posts
Posted 28 June 2015 - 03:02 PM
Looks liked my gauge isn't working... only ever goes up to 52 deg...
#59 jamesquintin
jamesquintin
  • 1,025 posts
Posted 22 March 2016 - 07:26 PM
ok as a final solution to this, the Minispare one works perfectly! The gauge goes up to abut 120 on the motorway now
#60 hennasxi
hennasxi
  • 117 posts
  • Local Club: LSMOC
Posted 27 July 2016 - 07:19 PM
I'm looking into oil temp gauges at the moment - there are two types fitted to MPi's, the older ones pre-99? with thicker bezels and the later ones fitted 99 onwards with thinner bezels.   They have completely different wiring connectors on the back, the older one has terminals labelled 1,2 and 3, the later ones have +, - and G.   Do these gauges use the same sensor in the engine block?   Reason I ask is they seem to have different resistance values if you measure across the terminals.   Has there only ever been one temp sensor since late 96 through to 2000, or did they change when the gauges changed type?  Any ideas?
