Posted 07 June 2014 - 09:46 PM
Posted 07 June 2014 - 09:50 PM
Clockwise richens on a HiF carb, which one are you running?
Edited by Minigirl, 07 June 2014 - 09:50 PM.
Posted 07 June 2014 - 09:51 PM
Posted 07 June 2014 - 09:56 PM
it's a su carbClockwise richens on a HiF carb, which one are you running?
Posted 07 June 2014 - 09:57 PM
Top nut on the bottom of a HS series carb secures the jet, the lower one adjusts the mixture, is the engine completely standard ?
Posted 07 June 2014 - 09:59 PM
. As fair as I know it's standardTop nut on the bottom of a HS series carb secures the jet, the lower one adjusts the mixture, is the engine completely standard ?
Posted 07 June 2014 - 10:04 PM
Mixture is the last thing to adjust once you have carried out a basic engine tune, tappets,plugs.points timing and air filter
Posted 07 June 2014 - 10:09 PM
. What do I have to do to them ATM I'm re seating the valves on a head what will be going on it . But when every I race the car runs ok but after a couple of races I have to put new plugs in because there choked up and won't work .Mixture is the last thing to adjust once you have carried out a basic engine tune, tappets,plugs.points timing and air filter
Posted 07 June 2014 - 10:13 PM
You ensure all those settings on the engine are setup correctly otherwise you cant set the mixture correct
Posted 07 June 2014 - 10:16 PM
Posted 07 June 2014 - 10:22 PM
Then set the mixture at idle to 3% and try from that starting point, if its still rich then check the float level, It may be set rich to compensate for the K&N which on a standard needle you may have flat spots in which case you would need a needle change
Posted 07 June 2014 - 10:25 PM
Posted 07 June 2014 - 10:38 PM
Raise the lifting pin to lift the piston by approximately 1/32 in (0.8mm).
- If the engine speed increases, the mixture strength of the carburettor is too rich.
- If the engine speed immediately decreases, the mixture strength of the carburettor is too weak.
- If the engine speed momentarily increases very slightly then returns to idle, then mixture strength at the carburettor is correct.
Or set it with a Exhaust gas Analyzer
Edited by KernowCooper, 07 June 2014 - 10:45 PM.
Posted 08 June 2014 - 09:23 AM
AAA is quite a rich needle as well if you have a standard setup...
Posted 08 June 2014 - 09:26 AM
AAC is the stock needle for a standard 998
use http://www.mintylamb.co.uk/suneedle/ to see the difference between the AAC and the Rich AAA needle you have
Mini Technical Sections →
Problems, Questions and Technical →
‘93 Spi Downpipe ReplacementStarted by ShabbyMini , 03 Apr 2025 ![]() |
93 Italian Job Wont StartStarted by Mattnumber2 , 28 Mar 2025 ![]() |
NewbieStarted by adenton , 23 Mar 2025 ![]() |
Tips On Buy An Used Su Hs4 CarbStarted by hfolguera , 17 Mar 2025 ![]() |
Engine Has Been Sat 10 YearsStarted by JHN_mini , 15 Mar 2025 ![]() |
