Mini Clubman Complete Rebuild
115 replies to this topic
#61 stumpypower
stumpypower
  • 126 posts
Posted 12 June 2014 - 07:59 PM
Thanks guys blue glueing is what we jokingly used to call welding  its to do with the weld pool and the joining of the two pieces of work
#62 henri1972
henri1972
  • 277 posts
Posted 13 June 2014 - 01:22 PM
used to work with a bloke called teflon welder ie non stick
#63 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,794 posts
Posted 13 June 2014 - 01:50 PM
we used to say that our apprentice had teflon overalls as nothing seemed to stick!
#64 stumpypower
stumpypower
  • 126 posts
Posted 14 June 2014 - 07:35 PM
I must stop watching the monster mini updates its giving me stupid ideas and a craving for tea biscuits. 25mil box section and a diner car lol
#65 stumpypower
stumpypower
  • 126 posts
Posted 15 June 2014 - 06:13 PM
Today has been spent tidying and rearranging the garage so Ihave room to work and my bike is out of harm's way. also sorted my sound system kettle and lighting  got hold of two a frame steel trellises that I plan to extend the top tube so its wider and put a tube coming forward  like a u section onto the end of this I will weld a subframe tower mounting bolt either side to locate it securely so there's no chance of it moving and something similaire for the rear
#66 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 07:40 PM
Today I made a start welded in some braces and started removing the door pillarw..I wante to leave the door hinge stiffener in place as a datum its heavily pitted and needs replacing I haven't got a spot weld drill bit so used a standard (I will be getting a spot weld bit tho ...the inner door pillar is being replaced anyway so not to much of an issue
#67 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 07:54 PM
Pic
#68 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:09 PM
Pic
#69 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:12 PM
Pic
#70 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:15 PM
Pic
#71 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:16 PM
Pic
#72 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:24 PM
Pic
#73 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:25 PM
Pic
#74 stumpypower
stumpypower
  • 126 posts
Posted 16 June 2014 - 08:38 PM
Hopefully tomorrow should see the  door step and pillar welded in place and a start made on the opposite side
#75 The Clubby Hubby
The Clubby Hubby
  • 555 posts
  • Local Club: Friends with minibitz
Posted 16 June 2014 - 09:20 PM
I have a front sumframe with the 2 bolts either side of the tower bolts if your interested thanks
