6
Mini Clubman Complete Rebuild
#31
Posted 08 June 2014 - 03:14 PM
#32
Posted 08 June 2014 - 05:18 PM
4 tf
4 tf
I need some help with this fellas what are the panels i need to repair this the door pillar ?? The part with the holes for hinges to go through whats this panel called what else do i need ??? Can you get a door pillar and doorstep complete
#33
Posted 08 June 2014 - 07:46 PM
hi stumpy power i have sent you a private message
#34
Posted 09 June 2014 - 01:37 PM
yes i did nd i took a look at the link thanks
#35
Posted 09 June 2014 - 03:17 PM
#36
Posted 09 June 2014 - 03:18 PM
#37
Posted 10 June 2014 - 02:11 PM
Ok so measured the door gap from the front edge of the quarter panel to the flat section of the a pillar (the part with the door hinge holes) so I measure flat against each hole from the very edge of the quarter panel and on the good side where it has an inner cill a doorstep and some sort of outer cill it measures 960 mm on the other side it measures. 963 mm the other side has no doorstep no rear half of inner cill but the floor pan is solid and so is the front halfof the inner cill . I guess it could be a combination of rust thinning the worst side more than the other which is rusty but still has its paint ect so do I need to get them identical by maybe using a ratchet strap to pull it in a little or go as is despite how rotten it is there's still a fair bit of strength in the pillar to be honest I can't see how its moved
#38
Posted 10 June 2014 - 02:25 PM
Making a list of replacement panels will get a few at a time so I don't get over whelmed and so I can afford it as ime on a shoe string budget for this with the other projects I have on the go as well will be replacing the whole floor complete with rear arches and boot floor so will be getting the pillars and door steps and glitch panels taken care of first that way the inner cill of the new floor has somewhere to be clamped and welded to ...I will also be using the brace bars as a jig by welding in mounting tabs that bolt to the seat belt bolt holes on the tunnel and and the handbrake handle mounting bracket and the gear stick aperature hoes at the front using my original floor as a jig before I cut it out when I fit the new one it will bolt in prior to welding in theory it should be in straight and true
#39
Posted 10 June 2014 - 04:41 PM
From
Mini 100
#40
Posted 10 June 2014 - 04:42 PM
#41
Posted 11 June 2014 - 04:43 PM
Pic
Posted 11 June 2014 - 04:54 PM
Hi you said you saw my brother mini topic on here you are very welcome to ask any question and did you get my message about phone number
From
Mini 100
#43
Posted 11 June 2014 - 04:55 PM
Pic
Posted 11 June 2014 - 04:57 PM
Pic
Posted 11 June 2014 - 04:58 PM
Ic
