Turbo Engine
#16
Posted 06 June 2014 - 12:52 PM
#17
Posted 06 June 2014 - 12:54 PM
#18
Posted 06 June 2014 - 12:56 PM
MPI tank will allow you to run higher boost too but this still depends on your engine spec.
#19
Posted 06 June 2014 - 01:41 PM
#20
Posted 06 June 2014 - 01:45 PM
Mpi tank it is best option and if it allows me run high boost even better :)
Is there anything else about turbos im missing out ?
#21
Posted 06 June 2014 - 01:49 PM
Why does using the mpi tank allow for higher boost ?
#22
Posted 06 June 2014 - 02:02 PM
Because you need to supply more fuel.
SPI pumps cant run as much fuel pressure as a MPI pump.
I am running a SPI tank at the moment and i can only run a max of about 10psi safely.
#23
Posted 06 June 2014 - 03:40 PM
Just because you can go faster it doesn't mean you are going to go faster, or are you saying better brakes because of the extra weight of the turbo?!really?
Why?Don't forget the most important thing if you are going to go turbo, you will need a good set of brakes.
#24
Posted 06 June 2014 - 05:21 PM
really?
Everyone seems to think that if you do anything performance enhancing, you'll suddenly be driving a lot faster.
If you think about it, on a duel carriageway, you'll be doing 70 whether you have 35hp or 235hp. The same brakes will stop each car equally (within reason).
Racing and track use are entirely different circumstances altogether, and would probably warrant better brakes.
#25
Posted 06 June 2014 - 06:19 PM
#26
Posted 06 June 2014 - 08:25 PM
Why? Servo's only reduce required pedal pressureThat is a good point but im sure you would need to at least put a servo on right ?
#27
Posted 06 June 2014 - 08:34 PM
#28
Posted 07 June 2014 - 08:56 AM
#29
Posted 07 June 2014 - 05:10 PM
LOLOL so you guys are saying your never gonna go over the speed limits? Nope point turboing it then... 60bhp is for than enough to get you too 70mph
It's not about how fast you go, but how quickly you get to that speed.
#30
Posted 07 June 2014 - 08:56 PM
You can't ******* a bullshitter guys
