On a freshly built engine using the standard pressure relief valve I would expect the idle to be a little more than 20psi when hot, and upwards of 50 when cold, but it's not the end of the world... only be concerned if it starts dropping into the teens when hot and on idle...
Likewise my 1330 I ran with an adjustable pressure relief valve and set it @ 50psi when running and 20psi when at idle running a 10/40 oil. There is no need to push high pressure oil, you just need a consistent supply.
