Hey guys what oil pressure is "normal" at idle? I'm just finished a rebuild with an sw8 cam and it idles at 20psi drives at a steady 50 psi
Idle Oil Pressure
Posted 04 June 2014 - 05:05 PM
Posted 04 June 2014 - 05:13 PM
There is no carved in stone value in spite of what you may find posted. The oil pressure will be a function of the engine condition, the grade of oil you are using, the engine operating temperature, and the engine idle speed.
That being said, for a freshly rebuilt engine 20 PSI is very low. What was replaced during the rebuild and what was not replaced (oil pump, bearings...)?
Posted 04 June 2014 - 05:19 PM
Mine idles at about 70 when cold, then 50 when warm (although after a high speed run it can drop as low as 35 for a few minutes)
Driving it is normally between 60 and 75 hot and cold.
Posted 04 June 2014 - 09:59 PM
All bearings where replaced and the pump too
Posted 04 June 2014 - 10:06 PM
Posted 04 June 2014 - 10:30 PM
Posted 05 June 2014 - 12:43 AM
I agree, the relief valve may be stuck open or not fully closing because of swarf. Hopefully that is all it is.
Posted 05 June 2014 - 01:18 AM
Has done for 30 years. Has never changed despite 2 full rebuilds.
You dont need super high pressure.
Posted 05 June 2014 - 02:53 AM
I think you may be surprised at just how inaccurate the gauge may be
Posted 05 June 2014 - 03:31 AM
I only use mechanical guages like Speco or VDO
Posted 05 June 2014 - 04:40 AM
I agree, 20 is a bit low.
My Rover is exactly the same - 70 cold idle, 50 warm idle and 60-75 driving. I am very, very curious though, why is it, that after an hour of freeway driving the oil pressure drops down to 35-40 for 15 minutes? The only possibility I can come up with is "thinning" of the oil itself, but I am wondering if anyone has a firm answer on this.
Posted 05 June 2014 - 05:01 AM
I asked the question on here before, and apparently its just that after a long fast drive the oil is very warm and, like you say that causes it to thin out.
Posted 05 June 2014 - 05:18 AM
I would be perfectly happy with that. They come out of the factory at 40-50psi.
Posted 05 June 2014 - 05:20 AM
Why do you think its to low. ?
Posted 05 June 2014 - 06:56 AM
Hi I'm liking the responses guys I'm using a scrappy halfords mineral oil to run it in, and I'm just running the standard bullet relief valve
Edited by cian, 05 June 2014 - 06:58 AM.
