Time to shake the dust off this thread...
Edited by buddylove, 10 March 2015 - 08:54 PM.
Posted 10 March 2015 - 08:53 PM
Posted 18 May 2015 - 08:41 PM
Posted 23 May 2015 - 08:42 PM
Posted 23 May 2015 - 08:53 PM
You've probably realised by now, but the callipers should have the bleed nipple at the top not bottom, hence why they were not bleeding and not working properly.
Posted 13 June 2015 - 06:16 AM
Posted 14 June 2015 - 01:11 AM
Yes, I did. Ended up pull those calipers anyways and going with new ones. Thanks for the heads up though!
Posted 14 June 2015 - 01:12 AM
Any updates?
Yes, about to update with a couple. Missed one update as well. Thanks for checking in. :)
6/8/15
So... I knew it would be something simple...
Worked on it at Chuck's last Saturday. I placed the spark plugs in the in the 1 3 4 2 order, but I had done it clockwise, not counter clockwise.
Thanks to Chuck for pointing that out, the Mini was running shortly after that. I still need to install the air cleaner and then we need to check to see if its idling / running right.
We also installed the new front brake hard line and new braided brake hoses. We also removed the vented 7.5 discs and re-installed the solid 7.5 discs. They are bit old, but can be run next season and then I will replace them with new ones. The KAD 7.5 calipers were also installed, but I didn't take any photos.
We still need to bleed the whole system, so I will get photos of the brake components then.
Next on the list:
KAD Rear Swaybar
KAD Rear Camber/Toe Brackets
Grill Buttons
Posted 14 June 2015 - 01:13 AM
Today:
Posted 18 June 2015 - 12:30 AM
Posted 26 June 2015 - 06:07 PM
Posted 27 June 2015 - 12:32 AM
Posted 27 June 2015 - 09:01 AM
Edited by timmy850, 27 June 2015 - 09:01 AM.
Posted 27 June 2015 - 11:21 PM
Posted 28 June 2015 - 06:33 PM
When you have set the Camber and Toe its useful to mark the outer locking square washer with a white marker in vertical and horizontal planes this will show and movement.
