Mpi Intermittent Cut Out
Best Answer fergiemike , 13 March 2015 - 02:02 PM
OK Finally got to the bottom of this problem.
Code reader said 13 Fuel Pump Relay or Purge Valve did component test on both and reader returned OK.
As discussed earlier I changed the main replay pack as this was most likely cause but that made no difference. (80 quid gone there)
So for last month I have been running with purge valve disconnected (just mutli-plug disconnected) and its never missed a beat.
Then last week once it was warmed up I reconnected the purge valve and guess what; it cut out 3 times in 2 miles.
Disconnected again and has run fine.
Took the valve off and tested on a battery and seems to open and close OK so guess its either sticking sometimes or its a wiring fault between the valve and ECU.
Does not seem to affect performance or economy (still getting 40/gal which is more than my Bini cooper s) so think I will just leave it disconnected as new part is 90 odd quid there are some second hand ones on ebay but they might just do same.
MOT in a couple of weeks so will see if it has affected the emissions figures.
Anyway I am very happy its sorted car is now my daily drive.
Thanks for all the advice and suggestions
Go to the full post
17 replies to this topic
#16 FlyingScot
FlyingScot
  • 2,664 posts
Posted 12 February 2015 - 10:54 PM
Which diagnostic set up and what is selected model wise?
FS
#17 fergiemike
fergiemike
  • 36 posts
Posted 13 February 2015 - 12:50 PM
its an ACR4 30255400
30352800 MAP pod with last update aug 2005
lead is 30214600
On the reader I selected ROVER MEMS 2J MINI 1300
I did check earths but will recheck that one
Edited by fergiemike, 13 February 2015 - 12:52 PM.
#18 fergiemike
fergiemike
  • 36 posts
Posted 13 March 2015 - 02:02 PM   Best Answer
