head gasket problems
miniman86
, Jun 19 2006 02:04 PM
9 replies to this topic
Posted 19 June 2006 - 02:04 PM
hey, i hope someone can help my poor little white mini!! she judders between 1000&2000rpm, when i replaced the head gasket last last year it stopped this for a little while then started doing it again, replaced plugs, leads and coil, abit better but not brilliant, hasn't got points & condenser as its electronic ignition, even does it when shes warmed up. i think its the head gasket but the compression is still up, any help would be grately appreciated! thanks alex
Posted 19 June 2006 - 05:04 PM
does the dashpot have enough oil in? have you checked timing and mixture?
Posted 20 June 2006 - 07:26 AM
ok well this gets better, going along this mornin and put my foot down n it felt a little underpowered then smoke came into the car and out of the bonnet around where the coil is, i thought the head gasket had gone but still running on all 4! got to work lifted the bonnet, (dont really now what im looking for except for white stuff under the oil cap) but nothing, so i thought thats weird, took out the key n she caried on runnin!!
Posted 20 June 2006 - 08:57 AM
white stuff under cap ?? Sounds morel ike lack of oil or at least a fouled mixture of said oil :S
Posted 20 June 2006 - 10:49 AM
soz i meant theres not meant 2 b white stuff under the oil cap, which theyre aint, oil all on correct level and new
Posted 20 June 2006 - 11:08 AM
If it carries on running when you take the key out, then I believe it is overheating a fair bit. The same happened to Doms Cooper when his rad was so low it caused the engine to overheat.
Posted 20 June 2006 - 11:41 AM
If the compression is OK, and there's no mayo, then chances are pretty slim that it's a head gasket issue.
Posted 20 June 2006 - 02:51 PM
hmmm, I'd check the coil,... the smoke..... that's a mystery to me.
Posted 20 June 2006 - 03:58 PM
Only thing i can think of now is lack of water or perhaps a water blockage as above. Is the water/coolant deteriorated much in colour?
Posted 20 June 2006 - 04:21 PM
i'm with retro 10's check the coil out. smoke isnt good
