Brake lights
8 replies to this topic
#1 ianbunyan
ianbunyan
  • 226 posts
Posted 19 June 2006 - 01:45 PM
Hi all,
I've done a search on TMF for 'brake light switch' but nothing of great relevance has come up, so asking here...
I have to press real hard on my brake pedal for the brake lights to work on my 74 austin mini. This has only happened recently.
Anyhoo, is it a plunger type switch near the brake pedal i need to look for and see what is wrong? or would there be something else i need to adjust somewhere? I've looked in the Haynes Manual but nothing there that I can see of?
My brake fluid levels are fine, and the brakes work just fine too.
Not driving her till I get this done as I know how annoying it is to follow someone who just slows down with no brake lights!!
Thankee :lol:
#2 dan__wright
dan__wright
  • 322 posts
Posted 19 June 2006 - 03:05 PM
yes, in front of the pedal arm there is a little white microswitch, move this back (loosen the screew and it will slide) tighten it up and try again.
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 19 June 2006 - 04:22 PM
so you are the later split brake system on your car, rather than the original single system which uses a pressure switch on the brake line for the brake light sender....
The later switch on the pedal box are a right pain, sometimes they just come undone and need tightenging, but more often than not replacing.
#4 ianbunyan
ianbunyan
  • 226 posts
Posted 20 June 2006 - 09:09 AM
Actually, I have the single brake system (all 4 brakes on one cylinder) ... so there is a pressure switch on the brake line ay? ... i THINK i have seen that in the engine bay on a piece of piping not to far from the flywheel cover. It has a plastic cone shaped cover on it, right??
A new one of these would do it then: http://www.minispare....aspx?pid=36731
#5 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 20 June 2006 - 09:16 AM
Yes, where the banjo junction is to split the NS and OS brake lines to the front wheels, instead of using a banjo bolt, there is a pressure sensor with a single two wires comming out of it.. I'll take a photo of mine...
Edited by GuessWorks, 20 June 2006 - 09:23 AM.
#6 ianbunyan
ianbunyan
  • 226 posts
Posted 20 June 2006 - 10:46 AM
Aaah excellent... I'm pretty sure that's the baby! Thanks for your help GW :(
#7 ianbunyan
ianbunyan
  • 226 posts
Posted 20 June 2006 - 09:49 PM
ps. can this be changed without bleeding the system?
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 20 June 2006 - 09:54 PM
Nope, you'll lose a bit of fluid doing this. Take off the reservoir cap and thread it back on with a thick-ish sheet of plastic under it to try to prevent loss, but some will always escape.
#9 ianbunyan
ianbunyan
  • 226 posts
Posted 21 June 2006 - 09:29 AM
In a true Napoleon Dynamite fashion, "Dangit!"
Well, time to call my mechanic (at the bottom of my road!) as I can't do stuff like that.
Thanks for all your help guys :(
