Leyland Clubman Resto
308 replies to this topic
#46 Jared Mk3
Jared Mk3
  • 1,974 posts
  • Local Club: MOCKZN
Posted 01 July 2014 - 08:48 AM
I won't ask how much that cost, let alone the shipping, but some nice goodies.
#47 colinf1
colinf1
  • 1,091 posts
Posted 01 July 2014 - 09:08 AM
Well lets put it this way, the shipping cost 30% of the total cost.
UK to regional Australia in 4 days is pretty darn good tho!
More goodies in the post today...this time switches.
Here we have the new switches for the switch panel, all roughly the same size handles, all are off at the same angle.
Box 1 of spares
Box 2
Carpet and Felt
Started to clean the front and rear screens, lots of sticker residue and screen bond to remove. Thankfully no chips or wiper scratches
And the rear seats, clean up but could do with a bit of a colour restore. Have conditioned the leather on them, so they are nice and soft and not dried out, just need to get the fading sorted...any one got any suggestions (without having to retrim them)
#48 colinf1
colinf1
  • 1,091 posts
Posted 02 July 2014 - 05:52 AM
Mock up of how the switch panel will look with these black handle switches...
Kinda looks like a mk1 mini switch panel, but the switches dont point up or down at such a big angle
#49 colinf1
colinf1
  • 1,091 posts
Posted 02 July 2014 - 07:10 AM
or this design, changed the icons to text, also changed fonts
#50 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 02 July 2014 - 09:45 AM
I like the first one.
#51 colinf1
colinf1
  • 1,091 posts
Posted 02 July 2014 - 10:58 AM
I'm leaning towards the 2nd one, as it's probably more viable that the laser will be able to etch it. The text is 3mm tall, so some sections of the icons are 0.25mm so probably won't be able to etch them properly.
I might send it to the laser cutters tomorrow, see if it's possible for the to do it..
#52 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 02 July 2014 - 12:10 PM
Good point, also think the second one has more a classic feel to it than the first one with the icons.
#53 colinf1
colinf1
  • 1,091 posts
Posted 05 July 2014 - 08:32 AM
had to work today so didnt get alot done, had planned to do a bit, hopefully get more time at it tomorrow.
Started stripping down the boot lid, removing the chrome bits and badge, aswell as the carpet liner on the inside.
Came across some yellow primer, then alot of bog. Was pretty deep, so will be to try and pull it backout.
A few holes, need to weld these
Big coat of paint stripper soon got the rest of the paint sorted.
Done a bit on the rear passenger side, seems to be bog free so far.
#54 colinf1
colinf1
  • 1,091 posts
Posted 06 July 2014 - 07:46 AM
I didnt realise the bottom part of the dash was only made from moulded foam...
Had a go at trying to remove the vinyl covering, only to hear a loud crack and a big chunk of foam! No worries, gonna redesign the switch panel to suit the slot, like the mk1/uk mini's.
Here is the pieces of what came out..
The metal slot
Boot lid stripped, ready to be welded
Both doors off, ready to strip and treat any nasties that may lie beneath
Another small rust hole.....and again filled with silicone rather than repairing it...under the rear seat bench
There is also a small bit of rust just below where the door check strap bolts onto the body. I'm happy with the progress I am making, should be able to spend more time on it as the evenings get longer and hotter in a month or so.
#55 colinf1
colinf1
  • 1,091 posts
Posted 07 July 2014 - 02:13 AM
Going to measure up that slot tonight, fit the heater unit back in temporarily and see if I can fit the heater controls and switches into the one slot.
Initial design layout
#56 colinf1
colinf1
  • 1,091 posts
Posted 07 July 2014 - 05:02 AM
A quick render of how it might look....still going of guessing dimensions, so I am hoping I can get it all to fit within the slot
#57 colinf1
colinf1
  • 1,091 posts
Posted 07 July 2014 - 07:44 AM
Have just measured up, needed to make drawing slighly smaller. Still looks alright.
Fitted heater unit in, top mounting bracket is in the way, so it will need moving back and an adapter bracket made to suit.
Ive got 10mm to play with from the bottom of the biggest switch to the bottom of the switch panel, plus plenty of room before you would be able to see it from under the dash, so pretty confident it will work ok.
#58 colinf1
colinf1
  • 1,091 posts
Posted 07 July 2014 - 11:52 PM
Update to dimensions, added heater control labels
#59 Jared Mk3
Jared Mk3
  • 1,974 posts
Posted 08 July 2014 - 09:47 AM
I like that!
#60 colinf1
colinf1
  • 1,091 posts
Posted 09 July 2014 - 03:32 AM
Sent it off to laser cutters to see if they can do it, and more importantly, see how much coin its gonna cost!
