My Daughter's 1976 Mini 1000 had 3 sound pads like Silent Coat stuck to the underside of the roof. Looks like it came out of the factory like it to me as the same pads are stuck to the sides in the back too.
Paul.
Posted 28 May 2014 - 05:11 PM
Paul.
Posted 28 May 2014 - 05:34 PM
Posted 28 May 2014 - 05:49 PM
Mine are not felt they're hard rubber by the look of them.
Paul.
Posted 28 May 2014 - 05:50 PM
Posted 28 May 2014 - 06:06 PM
A Quiet Mini
http://www.theminifo...1-a-quiet-mini/
BL launched the 'Quiet Mini' in the Summer of 1980. It incorporated extensive sound-deadening in the floorpan, front bulkhead, dashboard, roof and boot, plus a new headlining material. The effect was to produce what could more accurately be called a 'quieter Mini'. Over the years it was slowly reduced under cost reductions and in the front floorpan area it seemed to promote rust by trapping the water leaks.
Motor Magazine - July 5th 1980
Edited by mab01uk, 28 May 2014 - 06:06 PM.
Posted 28 May 2014 - 06:21 PM
Posted 28 May 2014 - 08:28 PM
Which thickness did you use 2mm/4mm ? Did you put any sound proof stuff as well?
No I didnt. The roof doesnt make much noise, just vibrates. Its the engine bulkhead you need to insulate well.
Posted 28 May 2014 - 08:33 PM
Posted 28 May 2014 - 08:52 PM
6 standard size carpet tiles glued to the roof with Evostick works very well.
I fitted the 'sound deadening' that Mini Spares sell (felt like stuff) and it's absolutely useless. The Mini is unbearable at anything above 50mph so now I'm going to rip it all out and fit Silent Coat absolutely everywhere I can get to to try and quieten it down a bit as it's a bit of an animal at the moment.
Paul.
Posted 28 May 2014 - 08:55 PM
Posted 28 May 2014 - 08:59 PM
Yes, I'm not convinced that 2mm of rubber is going to quieten it down enough so that I can have a conversation with somebody sat in the back at 60mph.
I heard that they don't sell the original stuff which was about 10mm thick foam with a further few mm of black tar on the top as it costs too much to post. But the stuff they now sell is about as much use as a chocolate teapot!
Posted 28 May 2014 - 09:01 PM
That is what classic car motoring is all about .
Posted 28 May 2014 - 09:05 PM
Yes but I fitted a radio and I can't hear the bloody thing hahaha
Edited by PaulColeman, 28 May 2014 - 09:06 PM.
Posted 29 May 2014 - 03:57 AM
