Sound Proofing Under The Roof Lining ?
30 replies to this topic
#1 Kt1966
Kt1966
  • 232 posts
Posted 27 May 2014 - 09:17 PM
Should there be some ? There wasn't anything when the old one came off, but I reckon there should be a sound deadening pad or 2 ? and some sound proof material (but how is it fixed on if it is there ?)
#2 Carlos W
Carlos W
  • 10,114 posts
Posted 27 May 2014 - 09:18 PM
Mine had some horrible brown material on it!
Not sure it did anything to deaden the sound though
#3 Kt1966
Kt1966
  • 232 posts
Posted 27 May 2014 - 09:21 PM
Thanks. Was it held in at all or just "hanging"? I was thinking of putting a bit of silent coat (or similar) on it and then some absorbent material, but don't know what. Strikes me the roof is just a big drum unless I do something with it....
#4 Carlos W
Carlos W
  • 10,114 posts
Posted 27 May 2014 - 09:27 PM
It was glued to the roof.
Its was a type of fabric stuff which tore very easily! I haven't stuck it back on, and don't plan to.
#5 ShaunaFTW
ShaunaFTW
  • 594 posts
  • Local Club: TurboMinis
Posted 27 May 2014 - 09:30 PM
Don't they just have that rectangle of it stuck to the middle of the roof? My boyfriends late 80's had that anyway when I took the headlining out a few weeks ago, not sure if it came from the factory like that though, there was about 4 layers of stuff on the floor so might have been added after :P
#6 Kt1966
Kt1966
  • 232 posts
Posted 27 May 2014 - 09:35 PM
Was it just sound proofing stuff or the sound deadening pad as well?
#7 ShaunaFTW
ShaunaFTW
  • 594 posts
Posted 27 May 2014 - 09:40 PM
Just sound deadening glued to the roof I think!
#8 Doodling
Doodling
    Formally known as phil.lingard
  • 260 posts
Posted 27 May 2014 - 09:57 PM
I've glued 1/4 inch thick foam to my roof. It's gone from a tinny tap to a dull thud.
It's great when your parked up in the rain but makes no difference when the engine running ( it's all I hear).
#9 Richie83
Richie83
  • 1,495 posts
Mine had a large foam pad as standard. Planning to silent coat the whole roof before putting the headliner back in.
#10 blackbelt1990
blackbelt1990
  • 2,614 posts
  • Local Club: Minimus Maximus
Posted 27 May 2014 - 09:58 PM
It varies with age, try and get something from an injection car if you're not going to buy new. They have a felt like pad stuck there, over 1cm thick.
#11 IainStallard
IainStallard
    I am the first status holder 2014.
  • 1,114 posts
  • Local Club: Box Hill Mini Club, CCMOC
My sidewalk has big sound deadening pads underneath the roof lining as standard :)
#12 henri1972
henri1972
  • 277 posts
Posted 28 May 2014 - 12:07 PM
mine has the perforated tar pads there are six of them just randomly stuck on
#13 Kt1966
Kt1966
  • 232 posts
Posted 28 May 2014 - 03:35 PM
Sounds like Silent Coat or similar would be a good option and then maybe something else. I've not used it before, but guessing it's ok for the roof
#14 Mini 360
Mini 360
  • 4,933 posts
  • Local Club: Independent
Posted 28 May 2014 - 03:37 PM
I put silent coat on mine.  6 sheets worked well.  Roof doesnt clang now, just gives a really deep and quiet thud
#15 Kt1966
Kt1966
  • 232 posts
Posted 28 May 2014 - 04:59 PM
Which thickness did you use 2mm/4mm ? Did you put any sound proof stuff as well?
