Hi!
I have a 94 spi wich i am leaving in the paintshop tomorow. My question is if i can remove the part of the crome on the hood and instead fi a mk1 grille with mustache. I am aware of that i might have to fill a couple of holes but will it fit?
Fitting Mk1 Grille On Mk4
Posted 27 May 2014 - 08:56 PM
Posted 27 May 2014 - 09:01 PM
yes but you will need to remove the lip that the chrome strip screws on to by drilling out the spot welds
Posted 27 May 2014 - 09:13 PM
Nice!! Thanks for quick answers.. The car is getting a new paintjob after a canister of glue exploded and covered the car in glue. So i want gain something new and fresh while im on it..
Minilee: Is it 8inch wheels on that car?
Where the F***K do you find 8 inch wheels to a mini?
Posted 28 May 2014 - 10:39 AM
8 inch sounds a touch small!
Standard wheel size on all a Mini's from 84 on was 12 inch, same for 1275GTs before - basically all cars that had disk brakes I think (or at least it's a good approximation..).
The exceptions being sportspack MPIs and ERA turbos which had 13 inch.
Earlier cars all had 10 inch wheels. To fit 10s on later cars you need to change the callipers or you'll have clearance issues.
These are the only sizes ever factory fitted to Minis.
Posted 28 May 2014 - 10:44 AM
Posted 28 May 2014 - 08:54 PM
How does your bonnet catch work with the bonnet pins,any issues? Do you need to release the pins before the standard catch, as I wanted to do similar.CheersYeah just drill the spot welds out :)
sorry for hijacking the post!
Posted 29 May 2014 - 05:33 PM
but you can easily stretch the lving hell out of it ;)
But i think i will stick to 7. I want the car to be drivable.
I did some modification on the bonnet today and i think it will look great.
Thanks for the help guys!
Posted 29 May 2014 - 07:04 PM
Carl at force racing wheels can do you 8 inch wide if you want http://www.force-racing.co.uk/home/
He did my 7" wide ones.
Posted 29 May 2014 - 08:49 PM
i just went on force racing and had a moment looks like i need to get saving for a set of them sexy 12s . my missus said go on ebay bless her so i showed her the difference in quality and she said you better get saving. damn you mudwerx
Posted 29 May 2014 - 09:45 PM
soz mate but i know the feeling, my set just landed last week and the lightness and quality of workmanship has to be seen to be belived.
little piccy of mine to help you save up.
Posted 30 May 2014 - 01:38 PM
Mudwerx: That is some serious awesome wheels!!!
