1989 Mini 30
I've done a search and can't find anything relevant.
Got Cherie back on the road recently after being laid up for 5 years, yesterday went to drain/flush/change coolant and oil. Coolant took ages but got it done eventually.
So moving onto oil, did the engine flush, then drained the oil, all fine.
However, I just can't get the old oil filter off. I have used a chain-type tool, that didn't work. I used a plier type tool, the big oil filter one. Tried to get a claw type tool but there is nowhere locally that has one. So, resorted to screwdriver trick, that didn't work either. Have tried turning it both ways in case I was going the wrong way.
I'm now left with a severely mangled oil filter that has barely budged, can't get a grip on, and a car I can't drive (which I need to get to work tomorrow).
Really stuck... help!
