Cylinders 2 & 3 Not Firing, First Start Up
Best Answer Yoda , 27 May 2014 - 02:41 PM
2012-04-14_201159_73_mg_midjet_firing_or
Well if its like this i am now stumped.
Go to the full post
51 replies to this topic
#31 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 11:43 AM
Ok guys,
Sorry DK for my error, when the timing marks are lined up no1 cylinder has both valves fully closed and the 'arms' can wiggle (I should mention they are roller rockers).
Non firing I determined by getting the engine to sort of idle as well as it can on 2 cylinders and then pull the plugs. Pulling cylinders 1 and 4 kill the engine. Cylinders 2 and 3 do nothing to the engine sound or revs.
I did the thumb test and all cylinders push my thumb away.
Something I have noticed, The sparking plugs on 2 and 3 are dry, which is confusing. There is a faint smell of fuel but nothing excessive.
The Carb is backfiring every so often, usually killing the engine dead.
Thank you all for your help.
#32 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 02:33 PM
Readjusted my tappets to 15 thou. Made no difference at all.
#33 Yoda
Yoda
  • 1,958 posts
Posted 27 May 2014 - 02:38 PM
From what you have now said, i am convinced you have the leads in the wrong order.
#34 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 02:41 PM
But I can't
1-3-4-2, Anticlockwise
#35 Yoda
Yoda
  • 1,958 posts
Posted 27 May 2014 - 02:41 PM   Best Answer
Edited by Yoda, 27 May 2014 - 02:42 PM.
#36 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 02:46 PM
Here is what it sort of looks like
#37 Outofthegame
Outofthegame
  • 70 posts
Well that makes sense woops
#38 Carlos W
Carlos W
  • 10,114 posts
Posted 27 May 2014 - 02:57 PM
Has that sorted it?
#39 flyer
flyer
  • 250 posts
  • Local Club: smoc
Posted 27 May 2014 - 02:59 PM
i am in dartford if you want me to come and look
#40 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 03:07 PM
Works fine now!!! actually it works really well.
It knocks a bit I think which is worrying me now, however I do have constant 80Psi oil pressure. Is it likely I'm being paranoid?
#41 Carlos W
Carlos W
  • 10,114 posts
Posted 27 May 2014 - 03:08 PM
Another TMF success.
You'll have to set the timing and mixture now it's running!
#42 Outofthegame
Outofthegame
  • 70 posts
Posted 27 May 2014 - 03:13 PM
Yes absolutely, I've never come across an A-series engine that revs so crazy. I touched the throttle and it just explodes into life.
I need to check the timing as you said, and the mixture I'll have to do as well as I can on the plugs at the moment, next stage, put the rest back together and take for an MOT
#43 Yoda
Yoda
  • 1,958 posts
Posted 27 May 2014 - 03:59 PM
To be of service, Glad i am.
What a shame you did not pick up on this in post #2
Yoda        #2
Posted 25 May 2014 - 12:16 PM
Check that you have the HT leads in the right order.
Edited by Yoda, 27 May 2014 - 04:03 PM.
#44 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 27 May 2014 - 05:34 PM
Its ok to say it Yoda but nothing like being shown it, well done that man
#45 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 27 May 2014 - 05:56 PM
Dave, I have never made things "sticky".  Could you take Yoda's picture and put it in the FAQ section so we can reference it in future posts?
