i have stripped my steering rack cause it was leaking, can any one please tell me what oil i should use or would grease be better?
Posted 23 May 2014 - 08:03 PM
Posted 23 May 2014 - 08:10 PM
I use grease & had no problems
Posted 23 May 2014 - 08:20 PM
Posted 23 May 2014 - 08:23 PM
cheers you guys guess it doesn't matter really doesn't work to hard really
Posted 23 May 2014 - 09:15 PM
It should be EP80 gear oil.
Posted 24 May 2014 - 08:34 PM
excellent ill go get some might as well use the proper stuff. should i fill it completely or 80%
Posted 24 May 2014 - 08:37 PM
Don't fill it completely as it won't be able to flow back into the rack from the gaiters and will blow the gaiters off when you go from one lock to the other.
The workshop manual will tell you the correct volume.
Posted 24 May 2014 - 09:49 PM
brill cheers mate
Posted 24 May 2014 - 10:12 PM
Posted 27 May 2014 - 07:10 PM
its a 1962 rack.
Posted 28 May 2014 - 04:34 AM
I'd use a high pressure grease
Posted 28 May 2014 - 08:50 AM
What age is it? Early racks up to (I think) mk2 used gear oil and are rebuildable. Later racks use grease and are considered unserviceable. If it's a later car it's unlikely it was the rack leaking to be honest.
How early is early though? My car is a '76, is that early enough for a rebuildable rack?
Posted 28 May 2014 - 07:12 PM
A 1962 rack requires EP80 or EP90 gear oil. I always use EP80 as EP90 gets very thick in mid-Winter.
Posted 29 May 2014 - 10:14 PM
