Stub Stack Filter
Posted 21 May 2014 - 09:25 PM
I been looking at MED site for a stub stack to buy themselves £25
With filter £90...
So have any of u guys just brought the sub stack and fitted
Your own air filter if so which one...
The one I see close is ramair but I don't know
Could u guys let me know
Posted 21 May 2014 - 09:27 PM
Posted 21 May 2014 - 09:33 PM
Posted 21 May 2014 - 09:42 PM
I'm fitting MED Stub Stacks and K&N Pancake filters to my twins. It is going to cost me £210 altogether.
And yes, do fit a filter, you wouldn't believe the amount of rubbish/birds that would get sucked into your engine if not using a filter. Especially if it is a road car.
Posted 21 May 2014 - 10:42 PM
I have a stub stack on mine inside a Cone Filter but its not the one you link to its the one from Somfords Mini
Posted 21 May 2014 - 10:45 PM
There meant to be the best on the market...
Posted 21 May 2014 - 10:47 PM
Don't fit a filter?
Ahhh don't think so
Posted 21 May 2014 - 10:53 PM
Posted 21 May 2014 - 10:55 PM
Sock filter?
http://www.thepiperc...0_p23375756.htm
Ahh I see stub now, probably a bit OTT then.
Edited by Outofthegame, 21 May 2014 - 11:03 PM.
Posted 21 May 2014 - 11:06 PM
Why not? Obviously I know why not but personally I think the positives outweigh the negatives, it's right at the back of the engine bay, how much cr*p really makes it up their?Ahhh don't think soDon't fit a filter?
Posted 21 May 2014 - 11:18 PM
Enough particles that is a very short while you'll be seeing blue smoke from the exhaust, you really cant run a road car without one.
Posted 22 May 2014 - 12:37 AM
I'm sure I read about a guy who got a bird stuck in one of his open ram pipes once. It only needs to be microscopic particles to damage an engine.
You even said yourself you can't be too careful with engine hygiene.
Edited by HarrysMini, 22 May 2014 - 12:37 AM.
Posted 22 May 2014 - 12:51 AM
In Vizard's book he mentioned running a car through a sealed track race and then emptying the contents of the air filter onto some paper. When he heated them to simulated being in the combustion chambers they turned into a paste similar to valve grinding paste.
K&N filters (according to his testing) pose no restriction to power, but save them getting full of grit.
Obviously you can't just wack one on and assume the engine's going to go better, they do need to be tuned and adjusted to the filter. A K&N with a stub stack or short velocity stack is the best option for power and filtering for an SU from his research.
Posted 22 May 2014 - 06:59 AM
i have a stubstack inside a K&N filter
Posted 22 May 2014 - 03:19 PM
Exactly the same as mini on the HIF44
