Before you put the castle nut back on, make sure the taper washer is in the hub, its a big chunky thing, so you cant miss it, then wind the nut on. When its tight put the wheel back on and lower the car back down and tighted the castle nut up as tight as you can. Check to see if the grooves in the nut line up with the split pin hole on the CV, if they dont DON'T LOOSEN THE NUT till they do, TIGHTEN IT A BIT MORE till they do, then put the split pin back in and bend it over
It's incorrect and dangerous advice !
NEVER EVER EVER tighten the stub axle nut up with the split bevel washer insitu, the torque wrench will give a false reading and 'click out' too early. Use the correct tool to pre-compress the bearing into the hub or make one out of 8mm thick plate with a 26mm hole in the middle.
The correct torque wrench setting for the stub axle castle nut is as follows:
Drum brake hub - 85lbft
Disc brake hub with on split pin hole - 180lbft then round to the next split pin hole (approx. 200lbft)
Disc brake hub with twin split pin hole - 150lbft then round to the next split pin hole
