Asbestos dust from the drum brakes?
Posted 17 June 2006 - 04:16 PM
What can i do to avoid absolutely any chance of breathing this stuff in? Will a regular bog-standard dusk mask do the job? These dusty conditions don't exactly help, so how can I identfy it?
Posted 17 June 2006 - 04:21 PM
Posted 17 June 2006 - 04:23 PM
Dusk mask just to be safe?
Posted 17 June 2006 - 04:30 PM
Posted 17 June 2006 - 04:33 PM
If you have a dust mask, it won't hurt at all to wear it whilst removing the drums, it is probably way over cautious, but it's better than getting a mouth full or lung full of brake dust (whether it's asbestos free or not).
Posted 17 June 2006 - 05:11 PM
Yes absestos is very dangerous and toxic but it's like any other carcinogen in that it takes a certain level of exposure to make you sick. A single particle in your lungs is not going to kill you. There's always a bit of it in the air. The whole world's exposure to asbestos was massively increased when the World Trade Centre collapsed since it was a 60's office block and riddled with the stuff.
If you're worried then definitely use a mask, use a drop cloth to catch the debris falling off the car and soak the whole affair in brake cleaner before and after the drum comes off (asbestos is absorbant and once it soaks something up it's too heavy to blow about). Work outside and try to do it on a windless day.
As has been said though the shoes on it by now are probably asbestos free but assuming that to be the case would be foolish when the precautions are so simple.
Edited by Dan, 17 June 2006 - 05:17 PM.
Posted 17 June 2006 - 05:34 PM
And no precautions either!
Posted 17 June 2006 - 05:54 PM
Now if i only i could get the bloody wheels off!
Posted 17 June 2006 - 08:26 PM
Posted 17 June 2006 - 10:00 PM
Posted 17 June 2006 - 10:31 PM
If they had been that dangerous over the last 20-ish years, I'd be dead by now the amount of pads and discs I've changed.........
Nah, just wait another twenty years when your lungs start to fail
Posted 17 June 2006 - 11:36 PM
