Took the head of the mini today (1275 std) as no 2 exhaust valve had seized in the guide resulting in no compression on no 2, took all 8 valves out, they all had top hat type stem seals fitted, I thought they were only fitted to the inlets, could this be why it seized, ( no lube) I will order a new set of ex. valves, will I need to replace the guides as well, on inspection they all look fine, would the seats need recutting if new guides were fitted? Thanks Martin.
Valve Stem Oil Seals !
Posted 19 May 2014 - 07:28 PM
Posted 19 May 2014 - 07:38 PM
some engines did have seals fitted to all valves.
best way to check if guides need changing is to fit valve and check for play. any movement usually indicates wear.
if the guides are replaced then the seats ideally need recutting to suit the new valves
you can not bother with re cutting the seats and get away with it but for best results i would recommend re cutting
Posted 19 May 2014 - 07:54 PM
Posted 19 May 2014 - 08:08 PM
Posted 19 May 2014 - 08:14 PM
Thanks Gremlin, so are you saying to leave the seals off the ex. valves? Martin.
Posted 19 May 2014 - 08:50 PM
Posted 19 May 2014 - 09:40 PM
Thanks for that, I will try without any. Martin.
Posted 19 May 2014 - 09:43 PM
Martin - were the exhaust valve stems smooth or scored when you took them out. Also watch out for the length of the valve stem, as the early S valves were shorter. But if it's a 940 head then chances are you should have later (longer) valves fitted.
Also using bronze valve guides may help avoid seizure when using stainless valves.
Posted 19 May 2014 - 09:45 PM
Ac
Edited by ACDodd, 19 May 2014 - 09:45 PM.
Posted 20 May 2014 - 04:33 PM
There have been problems with the phos-bronze guides where there was insufficient stem to guide clearance. I always use the chilled iron guides to prevent this possibility. I also fit stem seals on all the valves, just because I've always done so.
Posted 20 May 2014 - 05:08 PM
Thanks for all the replies, it was just no 2 cylinder ex. valve that nipped up, and yes it was slightly scored, they are cast guides. Martin.
