Flywheel Come Loose. Crank Salvageable?
Posted 16 May 2014 - 02:17 PM
My new engine and box was recently fitted. After 100ish miles the flywheel (verto system) came loose. Had the wok off and the keyway has snapped, horseshoe twisted and been ground down,and the hub in cluch all chewed up. Worse, the crank taper end is a scored mess. I've tried a new clutch and flywheel but it rocks as the taper isn't as it was.
Has anyone ever encountered this? Any fix or is it as I suspect a new crank?
As to how it happened I have no idea. The fitter swears blind he did everything correct although he confesses to not using a torque wrench so chances are his guesstimated 150lb on the nut was a bit out.
Any help appreciated. I'll upload photos asap but don't know how from a mobile.
Posted 16 May 2014 - 02:38 PM
Posted 16 May 2014 - 02:47 PM
Posted 16 May 2014 - 04:34 PM
Posted 16 May 2014 - 04:57 PM
I would sugest getting a torque wrench and inserting it.....
I do all mine to 150 and then an extra heave, so more like 175lb +, I also warm the flywheel before putting it on so it shrinks on a bit. in the oven on min for 1/2 hour...
Posted 16 May 2014 - 06:41 PM
Gearbox dude then had it back to remedy and then refit. Now this.
The problem is gearbox dude ain't got the dollars or insurance.
Posted 16 May 2014 - 06:45 PM
Difficult to be sure, but it does sound as though a new crank will be needed. The tail could possibly be built up with a professional metal spray and gring back, but that would cost more than a good used crank.
You need to persuade those who screwed up to re-do it F.O.C.
Posted 16 May 2014 - 06:53 PM
One bolt + one idiot = major aggro
Posted 16 May 2014 - 07:09 PM
Which engine do you have?
Cranks need not be expensive, but if you get one cheaply it may well need a re-grind and will, of course, require a full set of main, big end and thrust bearings, plus a new flywheel.
Posted 16 May 2014 - 07:25 PM
Posted 16 May 2014 - 09:02 PM
Posted 16 May 2014 - 09:05 PM
Posted 16 May 2014 - 09:11 PM
I don't think he realises you've bought a new flywheel
It was new before it fell off! Would it's little incident have damaged it?
Posted 16 May 2014 - 09:17 PM
