Posted 16 May 2014 - 10:08 PM
I had one similar to that one from screwfix, the 125mm is a problem as most good quality automotive paper is 150mm, i used it for one car but burnt it out, ok if just the one job though. I then changed to an air sander and that was brilliant but very noisy which is why now I have bought a mirka ceros, cost almost £300 but very quiet and feels as good as an air da to use, but I do have 2 or 3 cars to do so was worth the investment. Think sealey do a 150mm da for about £70 just it's shaped similar to an angle grinder. I would advise using mirka abranet paper though it's a little more expensive but lasts really well. Try your air da with a direct connection from the tank with larger hose first as it may manage ok and have a good 1/2 regulator and set it at about 80psi.
