Hvlp Or Lvlp Gun Thoughts
12 replies to this topic
#1 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 May 2014 - 09:50 PM
Bought some Burgen tools before and found the quality good, whats the opinion on this HVLP Gun?
http://www.ebay.co.u...984.m1423.l2649
My compressor is a 7.5cfm @90psi, remember I'm a sparkie so dont need big compressors, biggest thing I intend painting is my bonnet (stone chips), and the odd mark or two.
It has a 1mm nozzle and 4cfm so a bit bigger than most 0.8mm touch up guns. just wondered what the painters thoughts are here
#2 myredmini
myredmini
    My Mummy Says It's OK
  • 3,211 posts
  • Name: Dan
  • Local Club: BOG MOG
Posted 13 May 2014 - 10:08 PM
I would aim for a 1.3 or 1.4 tip for better paint flow. It might be an OK gun for a few small jobs but I would personally spend a bit more.
http://www.ebay.co.u...=item19c78d9831
This will be ideal and is a very good brand in the paint industry.
Hope this helps :thumbsup:
#3 ANON
ANON
  • 2,682 posts
  • Local Club: pony
Posted 13 May 2014 - 10:24 PM
at £13.10 you'll be lucky if it doesn't fall apart!!
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 13 May 2014 - 10:39 PM
These guns get good reviews for the price I haven't used one myself but at the price not much to lose really
#5 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 13 May 2014 - 11:16 PM
looking at Utube LVLP might be the way to go on my small jobs, there are guys on there painting MPVs with LVLP, I'm not in a hurry.
#6 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 May 2014 - 02:21 PM
What are the paint boys using here on TMF ? can you list ones you have and what you think. Checked the gun in myredmini;s link and that looks attractive and most likely the way to go ? only downside is for that model at that price they dont do any spares for it?
List up what your using and where you got it from price etc and any thing else I'd need to know about it
anyone using LVLP Guns ? anyone using one of these > http://www.ebay.co.u...=item1c3e1b06ea
Edited by KernowCooper, 14 May 2014 - 03:11 PM.
#7 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 May 2014 - 06:53 PM
Going to order one you so if anyone can jump in with ideas about HVLP or LVLP with my compressor?
#8 Daz1968
Daz1968
  • 2,058 posts
Posted 14 May 2014 - 09:44 PM
I use a devilbiss sri pro spraygun, low air usage, minimum overspray and a superb finish also very easy to clean and spares are available. I have painted my mini with it and as long as I keep my eye on paint level and top up from a premixed measuring cup have had no issues at all and as the gun uses about 3cfm I can run it with an airfed mask on my 3hp clarke industrial compressor. Not the cheapest of guns to buy but the ease of use and finish it achieves was worth the money.
#9 myredmini
myredmini
  • 3,211 posts
  • Name: Dan
Posted 14 May 2014 - 10:07 PM
I use a Iwata az3 hte2 and have the 1.8 and 1.3 tips so i can use it as an all rounder. Had fantastic results with it at work. Also because I use waterbased basecoats as well as solvent I needed a stainless gun body. It did set me back around £200 though. I will easily be spending more for another in the future but I am in the trade, if its just diy stuff, no need to go mad.
With this iwata all spares are available too.
:proud:
#10 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 14 May 2014 - 11:26 PM
I went with one of these to try see how it goes, http://www.ebay.co.u...=item1c3e1b06ea
#11 Daz1968
Daz1968
  • 2,058 posts
Posted 15 May 2014 - 06:57 AM
What type of paint are you painting, and what sized areas are you painting, as if clear over base then a small touch up is ideal for blending then the larger gun for clearing the whole panel.
#12 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 15 May 2014 - 11:32 AM
1K base and clear, biggest panel will be my bonnet, rest is just a touch up as requires as time goes on. My biggest restriction in my compressor as per post 1 which is why I'm trying the LVLP Gun.
#13 Daz1968
Daz1968
  • 2,058 posts
Posted 15 May 2014 - 06:06 PM
A mini spraygun will easily paint a mini bonnet so the negron one is probably fine for what you want
