Dry Or Wet Sand Primer?
Posted 13 May 2014 - 05:02 PM
Posted 13 May 2014 - 05:13 PM
Hope this helps
Posted 13 May 2014 - 05:30 PM
Posted 13 May 2014 - 05:32 PM
Dry when sanding anything other than top coat
Posted 13 May 2014 - 05:40 PM
Posted 13 May 2014 - 06:06 PM
Posted 13 May 2014 - 06:35 PM
Posted 13 May 2014 - 06:56 PM
They have downsides too.. The edge of the disc is very sharp and can/will damage edges..
Personally I'd block it with 320 dry then 500 dry then 800 wet on a soft block or just your hand..
Aslong as you leave it a couple of days at a reasonable temp' it should be fine..
Posted 13 May 2014 - 07:14 PM
Posted 13 May 2014 - 07:23 PM
Posted 13 May 2014 - 07:34 PM
They produce water vapour so aren't brilliant at drying things..
Posted 13 May 2014 - 08:24 PM
Posted 13 May 2014 - 08:48 PM
Posted 14 May 2014 - 11:58 AM
sorry to hijack this thread, but can anyone recommend a quality air DA sander (with dust extraction) so that I can use the abranet discs? I have a 3hp, 90litre 14cfm compressor. I was using a Clarke DA sander and that just doesn't budge when it touches a surface, or runs out of air which suggests it consumes a lot of air (although the book states 6cfm).
I plan on dry sanding epoxy primer. Many thanks in advance
Notay
