Posted 13 May 2014 - 12:11 AM
Posted 13 May 2014 - 05:35 AM
Sounds like the clutch may not be releasing completely.
I haven't done much adjustment on this myself yet, but these two articles claim to help with adjustment:
http://www.minimania...FAQ__non_Verto_
http://www.7ent.com/...adjustment.html
Posted 14 May 2014 - 08:15 AM
Thanks for the reply, It does seem like the isn't disengaging properly. Would this only happen on down shifts? Because when going up the gears, it's fine...
Posted 14 May 2014 - 10:52 AM
and then check between neutral and 4th.
Posted 14 May 2014 - 12:00 PM
Posted 14 May 2014 - 02:43 PM
That could be yes , check for a crunch when in neutral and selecting reverse.
Well i found today that my return spring has managed to split the rubber boot/seal on the slave cylinder... This will be drawing in air, yes??
It doesn't crunch into reverse nor 4th gear
If you give the clutch a few pumps does it help?
I've only tried pumping the clutch when stationary to try and make it go into 1st smoother, it didn't seem to make a difference though...
Mini Technical Sections →
Problems, Questions and Technical →
Low Compression Across The BoardStarted by Vinay-RS , 11 Nov 2024 engine |
Clutch Parts And FittingStarted by Apeman85 , 10 Nov 2024 engine |
1980 998Cc Engine - Can Someone Willing To Learn Strip And Rebuild An Engine?Started by LukeClassicMan , 04 Nov 2024 engine |
Answered
Low Oil Pressure On Fresh RebuildStarted by sgallegly , 29 Oct 2024 engine |
1995 Spi Clutch Not Disengaging After ReplacementStarted by David12 , 26 Oct 2024 engine |
