Where Do You Put The Rear Fog Light?
24 replies to this topic
#1 Dusky
Dusky
  • 5,322 posts
Posted 10 May 2014 - 11:01 AM
As in the title, show me pics of your rear red foglight on othe rplaces then the right/left bottom corner.
Need to install my foglight, but I want to do something special :P
#2 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,033 posts
  • Name: Neil
Posted 10 May 2014 - 11:05 AM
You can fit it in the middle of the rear valance much like the Peugeots. There was a thread about rear fogs on here so do a search in Google and you should find it.
I think if it's in Belgium it will need to be fitted either in the centre or the l/h side if it's registered there. Not sure what your rules and regs are for there. (I'm talking about a single rear fog light here and not two as fitted to some modern cars)
#3 Daniel_moody25
Daniel_moody25
  • 407 posts
I've seen people cut a hole in the rear valence in the centre and put them in there
#4 Kieranlee999
Kieranlee999
  • 1,401 posts
Posted 10 May 2014 - 11:10 AM
mines in the normal place :)
#5 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 10 May 2014 - 11:17 AM
there aren't many places apart from the back end you can fit a rear fog light
#6 Dusky
Dusky
  • 5,322 posts
Posted 10 May 2014 - 11:27 AM
Any pictures? Was thinking about that myself too, or th eboot lid.. But don't know how to seal from water etc then
#7 RedRallyMini
RedRallyMini
  • 309 posts
Posted 10 May 2014 - 03:17 PM
12. Achtermisllicht.
De achtermistlichten moeten voldoen aan de bepalingen van het koninklijk besluit van 6 maart 1975 betreffende de goedkeuring van achtermisllichlen voor de auto's en hun aanhangwagens. De achtermistlichten mogen slechts ontstoken kunnen worden door een afzonderlijke schakelaar, die slechts werkt wanneer de achterlichten branden. Die schakelaar mag evenwel ook dienen om de voormistlichlen te ontsteken.
De ontstoken achtermistlichten moeten aan de bestuurder gesignaleerd worden door een oranje verklikkerlichtje, aangebracht op een in het oog vallende plaats.
Wanneer er een achtermistlicht is, moet dit aangebracht zijn in het vertikale vlak door de lengteas van het voertuig of tussen dit vlak en de linkerrand van het voertuig.
De rand van het lichtdoorlatend gedeelte van het achtermistlicht moet zich bevinden op ten minste 10 cm van de rand van het lichtdoorlatend gedeelte van hel stoplicht.
De maximum-hoogte van het achtermistlicht mag 190 cm zijn voor de voertuigen voor traag vervoer.
In het geval van een sleep mag het achtermistlicht van het gesleepte voertuig alleen branden wanneer het montagesysteem van het achtermistlicht van het trekkend voertuig dusdanig is, dat de eleclrische stroomkring van dat lichl aulomatisch opengesteld wordt als het achtermistlicht van de aanhangwagen brandt.
So if I understand this correctly, you can put your fog light on the left or in the middle...
#8 Alex_B
Alex_B
  • 4,573 posts
Posted 10 May 2014 - 03:59 PM
Mounted mine to the centre of the rear subby
1045084_10201546475284379_645172903_n.jp
1044187_10201553149851239_282003473_n.jp
#9 musicmanno1
musicmanno1
  • 132 posts
Posted 10 May 2014 - 05:22 PM
I put mine in the centre and mounted it to the bumper (through the centre bracket !) did mean drilling through my new bumper bracket, and it is completely hidden so looks neat!
Edited by musicmanno1, 10 May 2014 - 05:32 PM.
#10 rik_t
rik_t
  • 276 posts
  • Local Club: Robin Hood
Posted 11 May 2014 - 03:32 PM
I have mine in the middle:
#11 mm man
mm man
  • 404 posts
Posted 11 May 2014 - 04:24 PM
I took my osr reversing light bulb out and fitted my fog lamp ( red bulb) in and wired it in accordingly on a fog lamp switch .
Then left a white reversing light nsr
#12 humph
humph
    How bad can it Be?
  • 1,095 posts
Posted 11 May 2014 - 04:28 PM
One of last months magazine feature cars (can't remember whether it was Miniworld or Minimag) had a similar set up, thought it look very neat.  Will be doing the same for my Elf when finished.  Our Mini has had it fitted into the rear light cluster by a previous owner.
#13 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 11 May 2014 - 06:42 PM
In the UK there are very specific regulations as to where the fog light can be and what type of light it must be...
I did write an FAQ which had a picture, but the picture has long since gone...
http://www.theminifo...rear-fog-light/
I suspect the same reg's apply in continental Europe but where it reads Right replace with Left for those who drive on the right ( wrong ) side of the road.
#14 HarrysMini
HarrysMini
    I do not have short legs!!!
  • 3,352 posts
Posted 11 May 2014 - 06:52 PM
This is actually illegal, so don't do this.
#15 stevede
stevede
    As seen on TV
  • 1,164 posts
  • Local Club: None
Posted 11 May 2014 - 07:28 PM
This was my option
