Recommended Respirator / Mask For 2 Part Epoxy Primer
7 replies to this topic
#1 JonnyAlpha
JonnyAlpha
  • 2,748 posts
  • Local Club: Exmoor Minis
Posted 09 May 2014 - 08:09 PM
Hi;
I am going to be using Jotun Jotamastic 87 2 Part Epoxy Primer for the underside of my Mini and need an A2 / P2 rated respirator / mask.
I have been using a 3M 4255 (For Welding) but these are supposed to be disposed of after 1 month of use so mines ready for the bin.
I was advised here to try a Moldex Half Mask Respirator with ABEK1 rated canister and a P2 or P3 filter from Farmchem.
Farchem no longer seem to stock them but I have found them here , here and on Amazon here
Anyone use this mask and is it any good? The additional particulate filter fitting seems a little flimsy? Any other recommendations for an A2 / P2 mask?
#2 jpw1275
jpw1275
  • 2,803 posts
Posted 09 May 2014 - 08:36 PM
How the Eck do you get a breathing mask on under a welding mask..... I must try this tomorrow to see if it works
#3 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 09 May 2014 - 08:42 PM
Managed with this one under my Siflite no problems, previously I was using these masks but suffered some breathing problems after a lot of welding, not sure if it was coincidental (cold / flu etc) but didn't want to risk it?
What do you guys use for welding? Not forgetting the original question of course :-)
#4 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 09 May 2014 - 08:50 PM
I was also following this advice:
Metal vapour and your lungs, kidneys, brain etc.
MIG welding and angle grinding results in metal vapours.
Aluminium alloy vapour and fumes from zinc coatings are poisonous. Exposure can result in heavy metal poisoning (welding shivers) - flu like symptoms that can persist for a few days. The zinc coating should be removed from galvanised steel before welding, and wear a proper charcoal welding mask when you go anywhere near zinc.
It doesn't stop there - the fumes from flux cored gas-less wire and ARC welding are nasty. Stainless gives off chromium, MIG and TIG arcs give off ozone. Welding should be carried out in a well ventilated area.
This stuff is cumulative. Professional workshops normally have extraction systems. A DIY approach might be to leave the garage door open when welding. For prolonged welding It's a good idea to wear a vapour mask.
Edited by JonnyAlpha, 09 May 2014 - 08:50 PM.
#5 bikewiz
bikewiz
  • 320 posts
  • Local Club: NEMO
Posted 09 May 2014 - 09:24 PM
I use a 3M 6000 series full face respirator with the multi gas filter 54186 and the 5N11 particulate filter. If you spray a lot with it you'll want the tear offs for the shield.
I think it works I can still type :-) I think, I am typing aren't I?
#6 henri1972
henri1972
  • 277 posts
Posted 10 May 2014 - 11:10 AM
i always use a british army s6 /s10 respirator if it stops NBC it was also checked by our ISO rep as i used it at my last employer which it passed and filters are only £6 each
#7 JonnyAlpha
JonnyAlpha
  • 2,748 posts
Posted 10 May 2014 - 01:49 PM
Now I definitely wouldn't get an S6 or S10 Respirator under my Welding Mask!!!
#8 kezzkitkat
kezzkitkat
  • 714 posts
Posted 10 May 2014 - 07:19 PM
Devibiss Full face air feed mask and respirator belt I usr mine all the time works brilliant and also give protection from any 2k products
Only problem is that occasional the visor has to be replaced from over spray but there fairly cheap
