As long as the brown wires on the original solenoid which fed the fusebox and the Honda Ignition switch switches the powerd circuits exactly the same then thats the bulk of power sorted, But shout again if you have issues.
What ecu are you using for the Honda the standard one? or are you using a basic aftermarket ecu which is a lot easier to setup wiring wise?
i dont understand. there is no mini engine bits whats so ever. the only bit that i have that goes to the engine still in the loom is those brown wires.
there is no solenoid I've cut all that out
no solenoid,
no coil
also the fuse box on mine has all the normal wire colours and number of wires going to it. i noticed that the white wire from the barrel goes to the fuse box directly which is why I'm confused lol
so what your saying is..
the brown wires are definitely the only live ones needed
the mini ignition barrel wiring would need to be connected to the honda ignition barrel so still switches the power on and off when the key is touched.
sound about right?
the problem i have is i don't have a barrel. so is there a way to surpass this to test it?
